Question about Danby DDR586R Dehumidifier
The compressor always stop. how can i feel the compressor?
  • 21 Answers
Sounds like it is out of refrigerant and The compressor is overheating. I wouldn't recommend touching it, it may burn your hand. It might be cheaper to replace it than to repair it.
Posted on Oct 21, 2013
How do I determine reason that my Danby Dehumidifier isn't cycling on to compressor for more than 3-4 seconds at a time? Fan always runs but compressor only kicks in for 3-4 seconds then back off.
I would say low on gas or bad switch/thermostat.
The compressor probably has a shutoff for low freon. You would need a set of gauges to check for that.
Bad thermostat? You'd need a ohm meter.
User error? What kinda settings or controls do you have on the control panel?
There was a recall on these in 2014 for catching on fire.
Gree Reannounces Dehumidifier Recall Due to Serious Fire and Burn Hazards...
Jul 16, 2015 | Danby DDR6009REE Dehumidifier
I have a DDR7009EE and the fan runs continuously even when the humidity in the room is below the setting on the machine. Shouldn't the fan stop when the desired humidity is reached?
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Jul 28, 2011 | Danby DDR5009EE Dehumidifier
Compressor is noisey
Are you sure it is the compressor and not the condenser fan? Check the compressor vibration mounts to be sure they are OK. Feel the in and out lines of the compressor (be careful) the out should be almost to hot to hold and the in should be cool to cold. If this is true then the probable solution is to replace the compressor.
Good Luck,
Gilshultz
Dec 02, 2009 | LG Goldstar LD65EL Dehumidifier
Humidity will not collect in bin, always dry when machine is left on for hours
Assuming there is moisture in the air, it could be several things. Be sure the unit is clean and the compressor and fan are running. If not it probably is the humidstat. The outlet line from the compressor should be warm and the return cold. If they are not and the compressor is operating you either have lost refrigerant or the compressor has failed.
Good Luck,
Gilsh
Nov 27, 2009 | Dehumidifiers
I am having Daewoo refrigerator Model DIR220. When I switch on the refrigerator the compressor starts after about 3minuites and stops in few seconds. fan motor works continuously. As the compressor stops...
the compressor has an internal overload to protect it from overheating. the compressor is cooled by the refrigerant passing over it. It could be a bad compressor,, bad charge of refrigerant, or simply dirty coils not allowing air movement
Nov 26, 2009 | Dehumidifiers
Fan runs ,coils are room temp. should they be hot or cold , no water is collecting in bottom
A dehumidifier is basically an air conditioner, so some coils should feel hot, the others should feel cold.
If no water is collecting, then the unit's compressor is not starting. Typically you have four possible failures causing this: the switch/wiring for the compressor has an open circuit, the motor-start capacitor for the compressor has failed, the compressor itself has failed, or all the refrigerant has leaked out.
If there is evidence that it is 'trying to start', but then clicking repeatedly, this can be a symptom that the refrigerant has leaked out, as some devices have a pressure switch to prevent compressor damage.
Also, a failed start-capacitor can also cause the click-click noise if the device has a current limiter switch on the compressor.
So the short answer is, it's broken :)
Oct 21, 2009 | Whirlpool AD25BBK Dehumidifier
Kenmore 580.51650000 dehumidifier: compressor cycles on and off as it should based on humidity setting but the fan is always running, even with the compressor off. Checked humid sensor. Any other...
fan should turn off when compressor not running, the relay switch is stuck open for the fan, and probably needs replacing, but even if it always runs there is no harm and it only uses like 15 watts
Aug 21, 2009 | Dehumidifiers
PLUGGED IT IN FOR THE FIRST TIME OF THE 2009 SEASON BUT IT WILL NOT PICK UP ANY WATER. IT HAD WORKED FINE FOR THE PAST 2 YEARS.
Try to feel the lines on the compressor. The thinner line is High press and should get hot. The fatter line is Low press and should feel cold. Cold enough to allow water vapor to condense on it and turn into droplets. If neither occurs, compressor has lost "freon" charge.
Jun 27, 2009 | Danby Dehumidifiers
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Dandy dehumidifier
attempt to feel the metal fins on the back of the unit. If they do not feel cool, then unit is either out of freon or compressor has failed or compressor is not running. If fins are cool, then insufficient air flow through unit -check fan- or room has very low humidity and humidistat is defective; not shutting down compressor.
Jun 24, 2007 | Danby DDR2504 Dehumidifier
Danby DDR586R Dehumidifier Logo
99 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
Colin Stickland
Colin Stickland
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
