Question about Toshiba SD-V296 DVD Player/VCR
No audio playing VCR tapes or DVD's - Toshiba SD-V296 DVD Player/VCR
  • YR Deloach
    YR Deloach Oct 22, 2013
    Thank you all for the suggestions; took me awhile to convince my 91 year father that the RCA (red/white) was defective. (dog chewing through it) I replaced it and it now has audio!
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: VCR thinks ALL tapes are write protected.
the record tab detection switch inside the machine is broken
Posted on Dec 13, 2007
SOURCE: TOSHIBA RD-XV45 DVD-VCR COMBO TURNING OFF ON ITS OWN
PROBLEM NOT YET SOLVED
Posted on Jun 21, 2009
atang1
  • 734 Answers
SOURCE: I cannot get it to record a vhs tape to a dvd.
You need a remote to setup the dvd record and vcr record. Then you have to do dvd initialization perhaps before you can dub from tape to dvd?
Posted on Dec 20, 2010
  • 100 Answers
SOURCE: can not get sound playing
What connections are you using for the DVD and VCR output for both the video and audio?
If you are using a "digital" signal (such as optical audio/HDMI/etc) the VCR audio will not pass through these outputs. You will need to connect up the analog (red/white) RCA connectors on the back of your unit to hear the VCR audio
I hope this help, Magoo
Posted on Mar 06, 2011
Testimonial: "so happy to get some assistance it is so appreciate when dealing with something that is so frustrating"
Can the sansui vcr/dvd combo record vcr tapes to a dvd?
No, the DVD section only plays DVDs, to record VCR tapes to DVD you need a ripping device that digitalize audio and video (convert step) and then transfer to DVD specifications this data to disk (record step). The easiest way to do this is using a USB video capture adapter connected to your PC with a DVD recorder drive installed, the software to do this commonly comes as a bonus in the setup disk of the adapter.
Mar 17, 2011 | Sansui VRDVD4001 DVD Player/VCR
Can not get sound playing a vcr tape but can get sound playing a dvd please help
Mar 06, 2011 | Toshiba DVR670 Player
How to record VCR tape on DVD with SV2000
if your vcr only has 2 outs (video / audio you will need a "Y" splitter a 1 female to 2 males )..plug in to dvd in audio left and right and video in........
press play on vcr and record on dvd.........(Please note any Disney tapes will not record on to dvd and some HBO recording may not also)
May 29, 2010 | Televison & Video
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
Vcr gets sound but no video. dvd works fine
it sounds like the video head is dirty and needs cleaning, buy a vcr cleaning tape and follow directions on how to clean the heads... Radio Shack should have the cleaning tape....hope this helps.
Dec 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox zv427mg9 sound problem - VCR/DVD combo connected to a Vizio VW42LFHD TV. After some playing around we got the DVD running OK. We can see video and hear the audio. However, the VCR does not play...
sr you can disconect hdmi cable and use a litle speaker and check for audio in rca cables output , when you put your vcr play you can have audio in rca red cable and rca white cable i think when you put hdmi your loose in rca the audio , remember in hdmi you have audio and video , if you dont have audio in vcr the audio head are bad thias is used only in vcr mode. good luck
Jul 08, 2009 | Televison & Video
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Can only get DVD audio when hooking it up to Goldstar VCR...
The DVD must be connected with the RCA jacks-plugs [usually black & red] to the INPUT of the VCR, not to the RF connector. You must press the VCR\TV button to VCR so that the VCR takes control.When you place a DVD movie or AUDIO program it could be copied to the VCR. or played through the VCR.
Nov 11, 2008 | Televison & Video
Burn dvd from vhs
i'm assuming you have a vcr to play your vhs tapes, just plug your audio/video cord from your vcr(out), plug into the audio/video vc10(in), start playing vcr and press rec botton whenever you want to start to record. make sure you can only use dvd+r. choose the quality for the length of time, at the end press 'function' to finalize the disc, then you are done.
Sep 06, 2008 | Sony VRD-VC10 DVD±RW Dual Layer...
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Toshiba SD-V296 DVD Player/VCR Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
