Question about JBL PB12 Subwoofer
My JBL12 4006 won't power on. I've checked all the connections to my Onkyo receiver and everything is fine.
Sound problems with an Onkyo receiver and a FIOS Set Top Box
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Apr 06, 2017 | Onkyo Audio Players & Recorders
TX-NR808 audio unexpectedly off
Hello, I am sorry about your issue. Please contact Onkyo at 800-229-1687 option #3 so that we can discuss options. Thank you, Onkyo USA.
Jun 22, 2017 | Onkyo TXNR808 Receiver
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
No component video with my Wii (component audio and HDMI video/audio both fine). It used to work fine, but now it won't show any picture regardless of which component IN I use. I checked all assigned...
Hello, I am sorry about your issue. Did you make any changes to the output resolution on the Wii. The output must be at 480i for the receiver to up-convert to HDMI. If there is a problem with the receiver I suggest a work around by connecting the component [red,blue,green] video outputs to the TV and the audio connections [red, white] to the receiver. Thank you, Onkyo USA
May 11, 2017 | Onkyo TX-SR606 Receiver
My Onkyo TS-SR604 has a "power on problem" whereby
Check to make sure the speakers are secure, if everything is fine! the problem is in the audio output ic's in the receiver. This will need a technician to take it further to find out how much the cost will entail.
Jan 11, 2011 | Onkyo TX-SR604 Receiver
Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Apr 15, 2009 | Onkyo TX-SR705 Receiver
Onkyo xsr502
Check the spekers first maybe one could be in bad conditions or the audio amplifier IC are about to get damaged.
Jun 17, 2008 | Onkyo TX-SR502 Receiver
JBL PB12 Subwoofer Logo
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
