Question about Curtis LCDVD326A TV
Does the LCDVD326A have the ability to attach headphones? If so, where are the connections?
    Master:
  • 269 Answers
First of all, here's the manual:
http://www.curtisint.com/html/custservice/manuals/CUR_LCDVD326A_EN.PDF
Refer to page 11. Apparently this set only has audio input connections (as analog audio) It does have an audio output but it is digital audio. you can't just plug in speakers or headphones, you need an adapter to convert digital to analog.
If you're a techie and want to know about SPDIF, look here:
Everything You Need to Know About the SPDIF Connection Hardware Secrets
You will need the converter:
Fosmon Digital to Analog Stereo Audio Converter Adapter Changes Digital...
and a cable to connect the adapter to the TV (choose the length you want)
AmazonBasics Digital Optical Audio Toslink Cable 6 Feet 1 8 Meters
they don't make it easy, do they?
Good luck
Posted on Aug 14, 2015
How do I connect a reversing camera to a Clarion VZ401E stereo so that it shows when reverse gear is selected.
If the stereo does not have the ability then take the connection from the reverse light switch at the gear selector!
Dec 27, 2014 | Clarion Vz401 Car Stereos with Bluetooth
How to connect headphones to Bose 3 2 1 GS III
Maybe there is one in the back of the system. check it out.
Jul 20, 2014 | Bose Audio Players & Recorders
Curtis lcdvd326a keeps blinking and says no signal
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 26, 2014 | Curtis LCDVD326A TV
Parts model
Maybe Curtis can tell you but most likely the screws are metric.
Jan 28, 2014 | Curtis LCDVD326A TV
Curtis tc lcdvd326a
see the diagram attached. However if you are using CRT tv FOR TO use the computer you must need some converter see it.
God bless you960a8614-3ccb-4da5-a137-b8027bcad5db.jpg9e539faa-e98c-4eaf-a01e-efc87cc5bc5d.jpg
Jul 27, 2013 | Televison & Video
I have a CD Stereo system SA-AK17, 120V, 145W, without speaker. I provided 2 speaker with the brand of Technics, input 200W(.music), 100W(DIN) each speaker. I bought Audio wire and connect speakers...
Some stereo system have the ability to switch off the speakers when playing via headphones. In others the headphone socket itself does the switching. However headphone sockets can become faulty and when the headphone plug is removed it doesn't restore sound to the speakers. It's very easy to fix this, with a check that the contacts are not bent out of place. Or you can rewire a new headphone socket, making a note of the wire connections before you replace it.
Sometimes it is quite difficult to get the speaker cable to make a good contact with the speaker sockets. You should check that they are making contact.
To test any loudspeaker just connect a 1.5 battery for a short time across the disconnected speaker. If working the speaker will pop!
As the sound is going to the headphones the amp seems to be OK and one of the above options should correct the problem.
Oct 27, 2017 | Panasonic SC-AK17 Shelf System
Can i attach headphones to my sony wega tv
One may connect headphones amplifier here:
TV Rear Panel
hope these helps,
thanks for choosing Fixya for assistance!
Aug 15, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Panassonic PR-HTX& head phones: both sides of the head phone work at the same volume. but with no stereo. all sounds come equally through both sides. I've opened them up and all the wires are...
That particular set of headphones are definitely a stereo set. This means the problem is with 3rd party hardware. If your using a jack adaptor it will need to support stereo. If you are using the headphones with your computer you need to make sure that the sound card and software all support and have stereo enabled. Manufacturer will not make a mistake like wiring in-correctly ;)
Feb 02, 2011 | Panasonic RP-HTX7 Consumer Headphones
What is process for on fm radio without headphone?
IT IS NOT POSSIBLE TO ON FM radio w/o head set as an headset acts as the recieving antenna for the transmitted radio signals from the radio station
Jul 21, 2009 | Nokia 3110 Cellular Phone
Connecting headphones to bose 321
try pushing mute and then turn volume up
Aug 22, 2007 | Bose 3 2 1 GSX System
Curtis LCDVD326A TV Logo
70 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
