Question about Danby DBC2760BLS (5 cu ft) Wine Cooler
Danby dbc2760bls only cools on right side. Left side fan is running but does not cool. There is no frost on the cooling lines as some suggest. Would it be the electronic box on the top of the left side?
4 Suggested Answers
huuum
  • 750 Answers
SOURCE: Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Posted on Oct 19, 2008
localwonder
  • 6784 Answers
SOURCE: Freezer works fridge not cooling on a Danby Designer fridge
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Jul 30, 2009
supernova278
  • 1932 Answers
SOURCE: dual zone wine cooler left
Please can you give the model number of your Danby refrigerator
Thank You
Posted on Oct 14, 2010
Unit started beeping now is blinking HI and is not cooling
if compressor is hot to touch , let cool and change compressor relay.
Nov 09, 2013 | Danby DBC2760BLS (5 cu ft) Wine Cooler
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
Unit does not cool when it is slid under the countertop. Temperature goes up right away.
Sorry to read about your problem, I hope this helps you out.
you must have lost the compressor cooling fan
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Danby DBC2760BLS (5 cu ft) Wine Cooler
Refrigerator running but not cooling
Check list:
fan motors all functioning
Cooling coils free and clean
Compressor cool to the touch
(compressor blazing hot bad relay)
Backside of freezer section frosting up
(bad defrost heater,thermostat,or timer)
Small line from compress is HOT
(cool high pressure line means low charge)
Suction line frosting up (overcharged)
Generic ice box Training manual
May 17, 2010 | Kenmore Refrigerators
Coils freeze up, replaced thermostat, defrost unit, mother board, only marginally works when set on 2-3
It is normal for the coils to frost evenly all over but if it's not defrosted it will build up preventing proper cooling. After replacing your defrost components make sure the frost is being melted. The motherboard determines when to defrost based you your use of the freezer/fridge. It should defrost from once a day to once every two or three days.
Is the fan in the freezer running? It won't cool right without it. It should run when the compressor runs.
Are the coils frosting evenly? Uneven frost means it is low on freon and requires a tech to repair.
Is the fan underneath the fridge near the compressor running when the compressor runs. If not It won't cool properly.
Does the compressor ever cut off as it should when it reaches the selected temp.
Jan 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Amana Side-by_Side SXD26VL is not cooling. The
clean cond coil at back of unit.
check amp draw on the compressor wires.
Sep 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Frigidaire Refrigerator not cooling
Is the fan on the bottom on? Do you hear the compressor kick off and on within a minute? No/ Is the evaporator fan running? Do you have frost on the evaporator? Frost is a sign that the defrost isnt working. If evap fan doesnt run it wont cool the refrigerator. If everything is running and no frost buildup in freezer then you have a sealed system problem and need of a tech.
Jul 25, 2009 | Kenmore 50522 / 50524 Side by Side...
Suddenly stopped cooling. Fan runs compressor doesn't.
Hi, If fans are running, most likely relay and/or capacitor. Do you here the compressor try to click on at all?
May 13, 2009 | Refrigerators
Refrigerator problem
3 most common things that cause this are a defrost problem (will notice frost build up on back freezer panel), bad evaporator fan motor (should hear fan running in the freezer), or bad damper (vent to the fridge section). If no frost and fan is running check for air flow out of the vent. It should be at the top of the fridge section.
Oct 01, 2007 | Kenmore 93361
Danby DBC2760BLS (5 cu ft) Wine Cooler Logo
98 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
