You won't be able to diagnose that without opening it and doing a visual inspection and then maybe follow with a continuity tester. it is likely a cold solder joint (bad connection) on the circuit board... or a broken wire going to the batteries... or just oxidation on the battery connections.
So you're telling me I need to send the laser/hypsometer back to Nikon?
whatever that is! :)
The Nikon Forestey Pro is a rangefinder hypsometer. It takes distances with a laser and computes heights and slopes using angles. I accidentally posted this in digital cameras I guess.
SOURCE: Nikon D50 Does Not Autofocus
replace the lithium battery 1.5X2 . then press then ok good, but does not work the drive motor was broken.
SOURCE: Canon PowerShot G6 Stopped Working
I have the same problem, but there is a internal battery. It is next to the other battery. It is a 2016 3.0v battery next to the hinge.
SOURCE: Why hasn't my Nikon Coolpix L15 ever really worked?
You have to change the 'battery type' in the settings menu to match the type of batteries you're using. I hadn't used the camera in months because of crappy battery life, when I finally read the manual and found that there was a setting for either NMH or Li etc.
SOURCE: I cannot activate Nikon Coolpix S210 (problem with ON/OFF button)
had a similar issue with my Pentax, it would power on and power back off. Tried playing with it for a while and it never recovered. Chances are its time to replace it. These new electronics are jam packed with lots of mini moving parts and are prone to excessive wear over time. they're are no servicable parts inside them unfortunately. I would try ebay for a reasonable replacement camera.
