Question about Sony KP-46WT510 46" Rear Projection HDTV
Sont kp-46wt510 blinks 4 times
I have a Sony projection TV KP-46WT510, when the set is turned on the standby light blinks four times. I have replaced IC8003(LA78045). (the board number is A1302708A) After replacing the IC I am still experiencing the same problem as the standby light is still blinking four times. I am asking if you can assist me with the problem and a service manual will be greatly appreciated. thanks in advance."
  • 4 more comments
  • faceface Sep 28, 2007
    i would.please send it to faceface1234@yahoo.com i change the ic8003 and the capsbut no changes.any ideas?
  • taoxiao38 Jan 18, 2008
    i have a sony KP43T75 (projection), when the set is turned on the
    standby light blinks four times, pauses, and starts blinking again.
    i doesnt power on.
  • a j Nov 25, 2008
    I have the same issue. Would it be possible to get a copy of the service manaul.
    Thanks in advance.
    andrewjjulian@charter.net
  • hornacek Dec 20, 2008
    I have this problem as well. My wife and I were watching the TV one night and the screen went out. Upon trying to restart the TV, the stand by light flashes 4 times and the TV never starts up. This model was built in 2004.
  • bubblegirl20 Mar 17, 2009
    Is it possible to send me the service guide too. I am having the same problem. I just replaced the voltage assembly, but now this new problem.
  • tscovanner Apr 07, 2009
    I have the same problem. Would you send me the troubleshooting guide?
    New Friend:
I have the same problem and i cant seem to figure it out. i have looked into it and tried about everything. if someone could help me i would greatly appreciate it!
Posted on Dec 21, 2013
Could you send the service manual to me as well? Any idea what this might cost to fix? Thanks
email: wilcko@verizon.net
Posted on Feb 13, 2008
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
Four blinks is a "vertical stop error" I have a pdf file of the service manual and troubleshooting guide. If you want it,let me know where to send it.
Posted on Sep 28, 2007
What's your problem?Hi, I have a Sony projection TV KP-46WT510 theres no picture or sound, but it still turns on and I can see the the on screen menu. When I turn it on the led blinks four times
You can Google and find the service manual which will explain what the 4 blinks means.
If you have the Sony remote with the set off:
Display, 5, Volume down, Power
If the set has it you will see a box appear on screen with a list of items--all should have a zero to the right of each---one with a number indicates the number of times that error has been detected.
Let me know if you have questions or cannot find what the four means and I will research it.
Mar 28, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
Hello, I have a Sony Projection Television Model number KP-46WT510. The problem I am having is when I turn it on it turns back off. The standby /timer light blinks six times. What could be possible...
Low B over voltage or over current shutdown its usually related to either the A board or the B board. You can get the replacement A board which includes the B board from www.tvrepairworld.com
Apr 26, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Try to turn on, it turns off right away and the stand by light flashes 6 times
Hi
Thanks for using FixYa. Standby/Timer light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. Also check +5 line is overloaded (A, B boards), +5 line is shorted (A, B boards). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
KP-46WT510 is blinking 8 times repeatedly on standby what is the problem?
Replace the Flyback transformer your correct flyback which is used in the WS510 and WT510 models is available at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-flyback-145328551/cName/flybacks
Oct 28, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
When i turn the TV on, a red light on the front of the set just flashes (standby light)
Let me know model and brand of TV if its other then Sony KP-46WT510 and also count red standby light flashes as there would be long pause between blinks.
These info will help me to find out possible solution.
Jul 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-51WS520 won't turn on
Something bad in power supply or horiz output.Possible bad gun.Needs a repair shop unless you know electronics.
Jul 07, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Replaced STK's, fuses ok, +/- 22 VDC ok, still can
did you checke the two 5amp IC protectors located on the G board? Those will usually blow when the original ICs fail.
Jun 12, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
IC1509 8-759-593-33 IC LA78045 35.98
Q1505 8-729-423-33 TRANSISTOR 2SC3311A-QRSTA
Replacement part
8-729-119-79 TRANSISTOR 2SC2785-FEK-HFE 1.02
these ic locations are different than yours but same part number.
is there a 2sc3311 near by LA78045?
Jan 10, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony kp-46wt510
I can't directly suggest a solution to this problem. but here is a link URL may be useful to you. http://getmanual.ru/tv/sb/sonyus.htm all the best
Sep 27, 2007 | Compaq iPAQ H3130
Sony KP-46WT510 46" Rear Projection HDTV Logo
483 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
