Question about Onan Cummins 5.5 HGJAB-1038 RV QG 5500 5500K Gasoline Generator Marqui
Won't stay running - Onan Cummins 5.5 HGJAB-1038 RV QG 5500 5500K Gasoline Generator Marqui
    Prodigy:
    An expert who has answered 500 questions.
  • Onan Expert
  • 573 Answers
Do you know how to get the codes from the start switch in the generator itself? if not I can help, that will narrow down what can cause it. There are many fcactors, fuel, control board A1, rotor brushes etc. So we need to determine more. If you need help getting the codes please post, if you still need help with this problem
Posted on Nov 14, 2013
Car won't stay running
If the problem only happens when the engine is cold, a bad electric sensor is likely to blame. If the car stalls even when the engine is warm, the cause is likely a faulty electric fuel pump.
Why is it that my car starts but won't stay running? ' Reference.com
https://www.reference.com/vehicles/car-starts-won-t-stay-running-6449388a9326285d Car won stay running Google Search
Dec 15, 2016 | Cars & Trucks
Starts but won't stay running
Did you changed fuel filter.
May 11, 2013 | Cars & Trucks
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
98 Expedition..5.4L 4WD..coded bank 1 bank 2....O2 sensors..LEAN....replaced both..no change..still same codes..now it won't stay running. Tried to code again..won't run long enough to get a c
all code readers will retrieve information stored while in the on position --doesnt need to be running ---when you rehook up scanner either resubmit or edit request with codes
Aug 15, 2017 | 1998 Ford Expedition
It will crank but won't stay running
installed new fuel pump and filter in 97 cavalier 2.2 the car will run for a couple seconds and shut off if you spary it with starting fluid it will stay running
Apr 13, 2012 | 2003 Dodge Durango
My on off button won't stay pressed down so the vacuum won't stay running.
Hi Melissa,
I'm sorry to hear you're having difficulties with your DC17. If the on/off switch doesn't seem to be working correctly, it's best if you get in touch with us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 13, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Won,t stay running
maby the timing is of or fuel injectors even spark plugs or cables
Jan 09, 2009 | 1984 Dodge Aries
Won`t crank
check your fuel pressure and also check your plug gaps and make sure you have a stong spark, you say it stays running once started on ether? does it run well or poorly? is it drivable or not please explain in more detail -please rate -jeff
Aug 16, 2008 | 1994 Oldsmobile Achieva Special Edition
Onan Cummins 5.5 HGJAB-1038 RV QG 5500 5500K Gasoline Generator Marqui Logo
145 people viewed this question
Top Onan Electrical Supplies Experts
Lawrence Oravetz
Jeff Hogancamp
Jeff Hogancamp
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
