Question about Vacuums
I have a Pullman power wash model VC-9388 it is leaking from the clean water tank where the rubber washer thingy releases the water, but the water is just pouring out, can we get replacement parts for this. Thank You, Denise
SOURCE: Broken Handle Release Pedal
what is part number for broken pedal release
Posted on Oct 18, 2008
SOURCE: Hoover Steam Vac clean water tank valve leaks
Honey! It's broke. You can manuever the little black valves out, but you will only find the hole in the clean water tank. I have the EXACT same problem. My advise to you is to take the valves, caps and handle off, sell them on EBAY and then buy you a whole new clean water tank.
Posted on Nov 18, 2008
  • 190 Answers
SOURCE: Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Posted on Oct 03, 2009
SOURCE: How do I fix Bissell Quicksteamer leaking from
I have the same problem... seems to be because of a bad, or worn, rubber gasket.
Posted on Jan 02, 2010
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
Trigger pin is stuck or something else is wrong. why is it constantly leaking water as soon as I plug it in?
You will need to provide more information as in the model AquaMate you are using as I can't determine which one by your information. You can also call and speak with a tech. at 800-640-2033.
Rainbow Vacuum Cleaner Systems Repair Center
Mar 28, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Hoover max extract V clean water leaking
get a new clean water tank or a seal to put on it from hoover.com/vacuumparts
Mar 16, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Water leaks
This model has a resevoir with a diaphram valve. The location of this part in under the clean water tank it has a black round gasket.. Your problem could be a bad resevior or something mechanical with the trigger and rod that when you pull on the trigger, solution is released.
Jan 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Scooba 5800
did you try priming the pump?
Sep 22, 2008 | iRobot 5800 Scooba Vacuum
Cleaner won't dispence cleaning solution
I have the same problem and each time I have to get the thing sent to Sydney to get the hose cleared out. Costing me $60 to $80 a pop.
Mar 10, 2008 | Pullman Holt Vacuums
Water leaks
I removed the clean water tank to refill it and all the cleaning solution poured out onto the floor. Turns out a plastic pin with a spring and a rubber washer also fell out onto the floor leaving a hole in the bottom of the tank. Calls to Hoover and local repair center all ended the same with the need to order a new clean water tank for about $45 and two weeks for delivery. Went to my local True Value Hardware store and within a few minutes we found a workaround using two 7/16"x 1/4"x3/32" #780 Ring from Danco Inc. Pulled off the proprietary Hoover O Ring that had obviously failed and put two of these O Rings on in its place and so far it is working perfectly. Total cost $1.35. Would be nice if Hoover cared to take better care of their customers by offering this almost free and quick solution to the problem.
Oct 13, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
No suction
Hmmm...I have the same problem...if you remove the water tank and the water collection bucket and look at what is remaining. Now step on the lever to lean the upright part back and there is a hose there that goes from the hand held hose into this hose into the dirty water tank. MINE is broken at that center point between the handheld hose and the dirty water square thingy...It's probably fixable...maybe this helps you?
Nov 05, 2006 | Hoover F7431-900 SteamVac Vacuum
Vacuums Logo
90 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
