Question about Emerson LC320EM8 32 in. LCD TV
When trhing to watch Netflix I get an error message"this content requires HDCP for playback" on my LC320EMX
    New Friend:
HDCP- High bandwith digital content protection is something that would be built into your tv. it prevents you from copying programs to another device. You have two options- one use a different type of cables like say rca red-white-yellow cables or for hd video. component blue green red cables and red and white cables for sound
Posted on Oct 19, 2013
I keep getting a message: HDCP unuauthorised. Content disabled. Across the screen.
Internet disable on cable box or televisio what are you using specify please
Nov 18, 2017 | Televison & Video
Hi ROKU stick does not show any films on Netflix, BBCiplayer etc.
Please contact ROKU customer support on this problem.
Dec 27, 2016 | Televison & Video
Sony bravia troubleshooting
"content error" is in your security for watching TV. Check your parental blocks and remove all of them.
Jan 07, 2014 | Televison & Video
Netflix cuts out and have to restart on my bravia tv, using only the smart tv to watch netflix
Sounds like your HDCP is failing [High-bandwidth Digital Content Protection]. HDCP is used to protect digital copyrighted content as it travels from a device to your TV, usually via a HDMI or DVI cable. Or by WiFi.
If HDCP fails on either end of the connection the default is to halt the stream, possible solution, reverse the ends of the cable or if this fails try a new cable. Don't go for a cheep cable though. But in the same vain you don't need one of the ultra expensive ones either.
If WiFi then the signal could be weak, this is nothing to do with the speed, but with the strength of the signal.
Changing the Wifi channel could work as this may obviate loss of strength due to interference. Also check other unrelated devices, for example a microwave oven with faulty shielding would cause issues when running.
Dec 01, 2013 | Computers & Internet
Sorry for the duplicate post, but somehow someone's not helpful solution got marked as solved, so I'm going to post again. I have a Sony Wega KP-51WS520. The problem is with the HDMI port. I have...
HDCP is causing the trouble You experience. Try using other video input connection for same set. If it works fine that way, the problem is that the rights protection (HDCP) is acting as "police" to prevent copying or reproduce unauthorized content. If only the HDMI is connected (disconnect all other inputs/outputs) on some sets, could be work fine.
Oct 10, 2013 | Sony KP-51WS520 51" Rear Projection...
DHCP
Hi Harryward_26, my name is Cheri Torres and I work on the Social Media Team at DISH. In order to comply with movie industry standards, DISH network, as well as all TV providers, must enforce content protection standards when required. This message indicates that your TV or connection is not High bandwidth Digital Copy Protection (HDCP) capable. It is likely your TV was manufactured before industry standards required HDCP. In order to resolve this issue you would need to replace your HDMI cable with component cables (red, green and blue). Once you do this you will be able to view the content. If you have any further questions or concerns feel free to email me direct at Cheri.Torres@Dish.com. Thanks!
May 05, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
Hdcp error mesage when connected to my freeview hd box.
What is a HDCP error? Here is a real life situation that happened that could happen to you. You just bought a Blu-ray Disc Player and connected it to your older HDTV with a HDMI cable. When you tried playing a Blu-ray disc a HDCP error was shown on the screen. The movie wouldn't play.
This is a known issue with HDCP, and it's one of the biggest hassles consumers will have to deal with when utilizing a HDMI cable on their HDTV. You will get a HDCP error if you try watching HDCP encoded content when using a HDMI cable.
The problem is that if HDCP exists anywhere in the video stream then all devices and cables accessing this content must be HDCP compliant. If one device or cable isn't HDCP compliant then you get a HDCP error.
The only solution is to either replace the HDMI cable with a non-digital cable or replace the HDCP-less device. This could mean buying a new HDTV. In fact, I worked with a reader last year troubleshooting a HDCP error on his TV. What happened is that he bought a Blu-ray Disc Player and connected everything properly only to get a HDCP error. After a few emails back and forth we discovered that his HDTV wasn't HDCP compatible, which is why he got the HDCP error.
The reader ended up buying a newer HDTV with HDCP, and his Blu-ray Disc Player worked perfectly with HDMI cables.
Nov 22, 2010 | Televison & Video
I cannot view HD channels (from freeview HD box) through my Sony str-dh810. I've narrowed the problem down to something called HDCP. When HDCP is on, I cannot view anything from my freeview box. Turning...
This piece of information should solve your problem:
High-bandwidth Digital Content Protection (HDCP) is a form of Digital Rights Management (DRM).
There is a licensing body that issues licenses for HDCP devices. Each HDCP-compliant device, like your Blu-ray player or Xbox, has a license and the ability to talk to the receiving device on the other end of the HDMI cable. The outputting device says "Hey display! Are you HDCP compliant? Here is my license, show me your license!" The display (or other HDCP compliant device) returns with "Why yes, I am legit! Here is my license!" When that process works, it happens within a thousandth of a second and you, the consumer, never even notice. You power on your Blu-ray player or DVR, it makes nice with your HDTV, and you live a happy life never knowing what HDCP even is.
if you have an older HDTV set that is not HDCP compliant then you cannot watch any HDCP compliant content on it. If you plug in your HDCP-compliant device to a non-compliant device, you'll either see a blank screen or an error message like "ERROR: NON-HDCP OUTPUT," "HDCP unauthorised," or simply "HDCP ERROR."
Short of buying a new television or giving up on your video game project the only way to deal with your HDCP compliance problem is to buy a cheap HDMI splitter that ignores HDCP requests.
Sep 25, 2017 | Sony STRDH810
I get the Secure HDCP link not found when I try to watch a dvd on my x-box 360
read this article..i am sure it will help you
http://formatwarcentral.com/2008/10/30/hdcp-required-for-xbox-360-hd-netflix-streaming/
Jun 13, 2009 | Microsoft Xbox 360 Console
Emerson LC320EM8 32 in. LCD TV Logo
111 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
