Question about Denon AVR-3801 Receiver
No sound fromDenon AVR-3801
I have just moved house and cannot get any sound from my amp. Not through speakers or headphones. Radio, TV, DVD all the same. Appreciate ideas. Thanks
  • 4 more comments
  • Sean777 Oct 10, 2007
    Power and all else seems ok. Just no sound output through speakers or headphones
  • Anonymous Nov 14, 2007
    I have the sam problem. I kann't get any sound from the Denon AVR-3802 Amp. I have sound only from the Pre-Amp Output but not from speaker or Hearphone.
    How kan help me.
  • Sean777 Jan 29, 2008
    You sure I will live to thank you if it works??
  • ourologamous Aug 17, 2008
    I don't get any sound from speaker and Hearphone of meine Denon AVR 3801 Amplifier.
    I 'm thankfull for any help.
  • sanjay27 Dec 12, 2008
    I tried the cable disconnect and reconnect, did'nt work for me. I was listening to mine then nothing. Checked all 7 fuses, no problems there. Not sure what to try next. Any ideas would be very thank full.
    I have the same problem. Was about to watch a movie and then it went silent. Checked the all 7 fuses, tried the cable fix posted earlier, it did'nt work for me. HELP!!!!
I just had the same problem. Lights up OK, but no sound. Take the case off, and find the harness that goes from the big power supply over to the amplifier board. The harness has grey, yellow blue purple and orange wires and is braided. With receiver on, I unplugged this harness from the board, then plugged back in. You'll see the red light on front flashing. Press power button twice, and see what happens. Worked for me!
Posted on Jan 20, 2008
  • 93 Answers
Is there any indications that you have power at all.
Posted on Oct 03, 2007
  • Mico Dukic Oct 10, 2007
    Try to check power cord, or fuse. Is there power on trafo at all.
    Also, do you have any LED indicator lit on front panel (i.e. standby/on)?
Denon AVR-3801 lights up,makes rapid clicking noises when amp tries to turn on. Clicking stops but unit doesn't play & sometimes the unit turns off. Occurred after lightning storm. What to do to fix?
Probably damaged by power surge. If you do not have experience diagnosing and repairing electronic circuits as well as having access to schematic diagrams then this is not a repair for you. Failure to replace all damaged components may result in damaging new parts.
Aug 16, 2016 | Denon Avr-3801 7.1 Home Theater Surround 7...
Blown up denon avr 3801
FIXYA can not do anything for you .
Nov 15, 2017 | Denon AVR-3801 Receiver
Poor DTS/DD5.1 from the AVR-3801
I also run 2 AVR 3801`s in my home, These are nice receivers, excellent build quality, about the DTS and DD 5.1 not up to par, I would check the Menu speaker set-up, be sure and make sure you have rear surrounds set up at surround speakers, NOT the rear speakers, they are for a 7.1 configuration, then set up the white noise test signal to balance all 6 channels, you need to have the powered subwoofer balanced properely, if no results of improvement then check your digital connections, I would recomment the fibre-optic, but the coaxial works also with great seperation signal, last I would investigate the playback unit of the DVD or DTS CD player, something in your set-up is amiss and you can acheive outstanding surround with this model of Denon, I can attest to this for my past experience setting up HT systems even with High End Outboard processors I always am amazed at the 3801 output quality, remember the 5 ch stereo is a Matrix DSP not even close to a true digital sound, and as for more amp power sure it always helps to have extra but the 3801 are true 105w @ 8 ohm 0.05 THD and are real, should power you Missions, the next level are denons 4800`s and 5800`s at 125 and 175 but I would stick with the 3800 and be content. Hope you have some better results after tweaking your settings.
Feb 17, 2009 | Denon AVR-3801 Receiver
Avr 3802 can i hook up 2 sets of front speakers
well depending on the wattage of the speakers your trying to hook up to the amp if they exeed the maximum wattage then theres a chance u *could* blow a fuse nothing more then that, a fuse protects more expsinsive devices in ur amp, an if ur system keeps blowing fuses after doing that add up the watts 2 all ur speakers,
and remove the less needed
Hope you find this usfull
Feb 10, 2009 | Denon AVR-3801 Receiver
Need help connecting PS3 to my Denon AVR-3801
You could try sticking a vcr/dvd player in between the connections and using those input/outputs instead.
Dec 31, 2008 | Denon AVR-3801 Receiver
Denon avr 3801
Are you using the composite outputs? The menu just come up from the S- VIDEO and VIDEO outputs. If this not solve the problem, chances are that the IC that handle the menu display is damaged.
Hope this helps
Jan 08, 2008 | Denon AVR-3801 Receiver
Second zone not working
This amp allows you to pick a secondary source for those other rooms. Did you by chance accidentally change it from the "SOURCE" designation that makes room 2 listen to same thing as room 1? Just a thought.
Dec 04, 2007 | Denon AVR-3801 Receiver
Denon AVR-3801
Is the signal set to "ANALOG" or "DIGITAL"?
Sep 29, 2007 | Denon AVR-3801 Receiver
Denon AVR-3801 Receiver Logo
706 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
