Question about Craftsman Garden
Starts ok but as soon as I go to use it stalls
  • Craftsman Master
  • 2,760 Answers
If your saying it stalls as soon as you go off "choke" then you've got a fuel flow problem , ck the simple things 1st , fuel filter (inside tank) if its got dark rings round it then replace it , ck to see if your fuel lines are "flat" any place along there path , ck that your primer bulb is not leaking (air or fuel) , try running it on choke with some automotive fuel cleaner in the fuel tank for a while this helps to loosen deposits inside carb
Posted on Jun 11, 2015
2006 golf starts but soon rpm drops then stalls. will start again but soon stalls
I had a 78 rabbit did the same thing. It was the fuel pump relay. The connector was under size and burnt up. When you star the car on the old Rabbit the pump runs off the ignition switch. Once it starts the relay needs a pulse from the distributor to let it know that the car is running and keep the pump running after it starts. If not the relay times out and pump stops pumping gas. Its for safety so if in a accident and the engine stops the pump wont pour out gas
Jul 25, 2017 | Cars & Trucks
If you let truck idle for a while it will stall and once again must let it sit for a few minutes and it will start.
How to Fix a Car That Stalls: 7 Steps (with Pictures) - wikiHow
www.wikihow.com > ... > Cars > Car Maintenance and RepairwikiHowFortunately, this usually does not signal a major repair to your vehicle, and it cangenerally be ... Does the car idle roughly and stall when at idle? .... has been running for a while, the fuel pump may overheat and stop working, stalling the car.
Nov 14, 2015 | Cars & Trucks
LT133 lawn tractor starts then stops. no spark,has gas filter ok,cleaned safety cutoff switch under seat. mower starts up,runs for 20 sec then stops.
Does the engine start up every time right when it shuts off, or will the engine not start until it's cooled off? And when the engine is running for the 20 seconds........ does it give any indication that it is going to stall, or does it abruptly shuts off with no indication of stalling? Let me know and I'll try to get back to you as soon as I can.
Oct 07, 2013 | Garden
1993 pontiac grand am stalls and misses
It could be the coil is getting old. They begin to lose function when they warm up.
Jun 23, 2012 | 1993 Pontiac Grand Am
Car stalls unless gas constantly supplied otherwise car dies all dash lights come on usually on start up
Inspect and clean IAC valve (idle air control valve), replace if necessary. If IAC is Ok, please provide additional info!! Does your vehicle experience random or repeated hard starts?? Is your "service engine soon" light on?? These vehicles are known for faulty crank position sensor, usual symptoms are: hard starts, random/constant stalls, SES light on, misfire or no start. Some or all symptoms may or may not occur simultaneously.
Oct 11, 2010 | 2000 Oldsmobile Intrigue
My 1994 suzuki intruder starts but as soon as you
loose or broken ground wire ,could be broke under insulation, vibration of motor makes it lose contact. probably on gear indicator switch.
Jul 28, 2010 | 1995 Suzuki VS 1400 Intruder
My CPI Hussar 125cc scooter starts but stalls as
cine i-mi poate spune *** se regleaza colbutorii la motor hussar 125?
Mar 02, 2010 | 2005 MBK Flame X
1996 VS V6 commodore starts ok then stalls after
have you checked fuel filter,check risistance on your throttle position sensor,could be faulty fuel pressure regulator,check the basics first,
Apr 26, 2009 | Graco Spree 511 Holden Travel System...
2006 bonneville starts ok , but stalls as soon as i engage first gear ? How would i fix this problem?
Hi I am not entirely familiar with this model, but check if the side side has a switch. If this is faulty, this can stop the motor when placed into gear. Hope this helps
Mar 25, 2009 | 2001 Triumph Triumph Bonneville
Stalls after it runs awhile,
egr valve is open, have it checked.it might be the egr valve itself or the siolinoid
Jul 22, 2008 | 1995 Pontiac Sunfire
Garden Logo
197 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
