Question about Samsung BD-E5400/ZA BLURAY PLAYER BD WISE ANYNET DVD UPSCALE JPEG MPEG2/4 WMV MP3 BF 887276000206
Wireless connection established cannot connect external network
Where do I fine SSID Name & Encryption Key
If you are trying to set up a router and need to establish the SSID name and WPA encryption key, you will need to sign into the router using the routers IP address. Input the userid and password, then go to the wireless network setup page. Here is where you enable wireless operation, establish the SSID, and generate the encryption key or passphrase.
If you are trying to connect to someone else's wireless network, you need to know their SSID so that when you do a search for available networks you can determine which is theirs. Once that is established, if they give you the encryption key or passphrase, you can attempt to connect to their network. With the encryption key or passphrase, you will not be able to connect.
Mar 15, 2015 | Motorola Computers & Internet
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
Tip
Configure Wireless Zero Configuration to configure wireless connection on XP...
Configure Wireless Zero Configuration to connect to wireless network on your wireless XP computer.
Below mentioned steps will help enable Wireless Zero Configuration on your XP computer and achieve wireless connectivity. These steps applies to your XP wireless computer (Desktops and laptops) with external or built in wireless cards.
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight the SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button. You should have successfully established a wireless network connection.
The above steps will help you in the configuration of wireless connectivity if you are not aware about the settings of wireless connection utility installed on the computer.
on Mar 18, 2010 | Computers & Internet
My wireless USB adapter is not getting connected to the network, what do I do
prior computers have builtin network adapters that functioned as cable connection either dial up phone lin or ethernet cable connections. Computer of the recent generation have wireless adaptors that derive connective within radius of modems also known as wifi. Observe the computers made models as reference to ascertain whether requires cable connection to network or capable of wireless reception. Computers that are provided network structures by an expert would recognise either as requiring cable or wireless. Depending on the coniditon of computer structures requesting to establish a network structure is acheivable. Refer with a computer networkin technician that would evaluate the devices at the location to ascertain the requisite structures to establish networking telecommunications. For example, refering with an expert ascertains that the computer requires modems to capture the signals or modern devices require a miniature adaptor device attacked to the computer.
Feb 19, 2011 | Linksys Computers & Internet
I dont know my wpa key to get online
Use an Ethernet cable between the network-port on your computer and one of the LAN ports on your wireless router.
Start Internet Explorer.
Connect to the web-server "inside" the router.
Run the "Wireless Networking Setup Wizard", to establish an SSID, choose an encryption-level (use 'WPA'), and to establish a password/pass-phrase/network-key.
Use the SSID and the password to connect to your newly-configured wireless network.
Sep 24, 2010 | Computers & Internet
I have a new samsung BD-C6500 and can't get it connected to my wireless network. The closet I can get is this error message that says ''Physical connection established but cannot connect to external...
I had the same problem. You are right, Samsung tech support is awful. When I pulled the system out of my cabinet I was able to connect wirelessly. But in the cabinet it wouldn't work. I think my cabinet was blocking the wireless signal. Fortunately, I have a wireless ethernet bridge with a gigabit switch on my cabinet that hooks up my Panasonic plasma. I ran an ethernet cable to the BD-C6500 and the problem was resolved. If there is any way, try running an ethernet cable to your player. I know this defeats the purpose of wireless, but it worked for me.
Mar 09, 2010 | Televison & Video
Netgear wgt624 with WGt111 usb wireless connection showing red no connection when using netgear wizard programme
Follow the steps to configure wireless connection :
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connect
Jun 08, 2009 | NetGear WGT624 Wireless Router
Experiencing error when connecting to wireless router
I've had this happen before when using a USB wireless device. Is the wireless on your system built in? Or do you connect it to a USB port? The external devices sometimes try to use their own software to configure wireless so you can shut it off and just use the Windows wireless tool. I assume you setup the wireless with a security key and entered that key into your system to try and connect? Let me know if any of that helps and rate the solution if it does!
Mar 31, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Psp internet connection
common is there anything you can do to fix it
Jul 28, 2008 | Sony PlayStation Portable (PSP) Console
The microsoft wireless adapter on my Xbox360 does not connect to my wireless network
How Can I connect a network adapter from my room to downstairs about 20 yards away?
I need XBOX LIVE badly, everyone has it cmon FIXYA help me out on this.
The router downstairs is a TalkTalk modem help me!
Jun 28, 2008 | Computers & Internet
Samsung BD-E5400/ZA BLURAY PLAYER BD WISE ANYNET DVD UPSCALE JPEG MPEG2/4 WMV MP3 BF 887276000206 Logo
15 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
