Question about Home Decorators Collection Charmglow Gourmet Luxury Island 84.5"hx95.25"w black
We have a charmglo CGL300TQ I am knowledgeable of
We have a charmglo CGL300TQ I am knowledgeable of propane and propane equipment I know most propane stoves when there is a big yellow flame it is to much air mixing with the propane. Most stove come with a cap or a cover that you can adjust to adjust the air intake This is one does not have that . Some also can be adjusted by the threaded coupling that the supply line screws to on the stove this one does not appear to be adjustable Any info on adjusting the air would be appreciated or a manual of one
Propane stove oven producing strong smell on preheat only. Tech replaced igniter - problem persists. other appliances are ok. GE Profile model JGBP86.
What kind of smell? Propane companies add an egg like smell on the bottom of the tanks so you know you are close to empty. Check your tank if it is full.
Jan 28, 2017 | GE Washing Machines
I have a Charmglow CGL300TQ gas heater and it will not stay lit over night. How do you figure it out and where can I buy parts for it.
Contact Charm glo thru their website and ask tech support .I do not recommend DIY for gas appliances as 1 mistake is deadly
Dec 02, 2016 | Heating & Cooling
I wish to know the proper propane connection as pressure,regulator is it required before connection at heater
I do not recommend someone to tamper with propane connections or regulators unless you are knowledgeable with it. Propane is a "very" powerful gas. Set up properly it is Great. But dangerous if done improperly. Call a professional for your safety.
Dec 22, 2013 | Dometic Heating & Cooling
Orange flames on two Blue-Flame heaters, dual fuel, currently running propane.
Could be that the burner needs cleaning dirt in the burner tubes
Nov 02, 2012 | Blue Flame Heating & Cooling
I have a Charmglow propane heater model CGL300TQ with a bad fan. Where can I find parts for this stove and does Charmglow have a website for parts?
Depends what is actually wrong with fan, if tis the blower barrel part you can by replacements but if its the fan and you van't find manufacturer try an commercial or indutrial fan place to match the one you have be careful to make sure that it is electrically compatible and that it will connect to heater safely and do as old fan did as fan speeds on heaters can be important
Nov 17, 2010 | Stoves Heating & Cooling
Charmglow model cgl300tq. cannot seem to get enough gas to make ignition! i keep pilot inlet tube clean. how can i tell if it is the regulator. it is definitely a gas flow problem!
You will need a manometer to determine your gas pressure, the amount required is posted on your appliance. Take both a static and dynamic reading on the inlet side of the gas valve. If it is not high enough consult a plumber. If it is take a reading on the manifold side. If the gas pressure is too low again consult a plumber. If it is within spec check orifaces and burner tubes if any for debris and spiders.
Mar 06, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
I believe i am being charged exorbitant fees for connection of my propane tank. situation: I have propane for my range top. There is NO pilot on the range (we light the burners when the propane is turned...
How fast did the propane run out? If there was a leak (which would cause the propane tank to empty a lot faster than normal use) you would be able to smell it. You can check for leaks yourself using soapy water; apply soapy water to the connection and look for bubbles...bubbles means there is a leak...no bubbles means everything is good. I think you got ripped off but I won't know for sure unless you can tell how fast the propane ran out.
Nov 23, 2009 | Grilling
Our charmglo ventless fireplace pilot will not stay lit. It started to go off including the pilot lite. Where can we find replacement parts for this problem?
I have the same problem with my Charglo fireplace. The propane company checked preasure and they even replaced the regulator. I am very disappointed with this and am afraid to use it. I have contacted Charmglo in the past and they were useless.
May 18, 2009 | Home Decorators Collection Charmglow...
Home Decorators Collection Charmglow Gourmet Luxury Island 84.5"hx95.25"w black Logo
141 people viewed this question
Top Home Decorators Collection Grilling Experts
Paul Carew
Tom Chichester
Mohammad Navaid
Mohammad Navaid
Level 1 Expert
Are you a Home Decorators Collection Grilling Expert? Answer questions, earn points and help others
