Question about Wolf Range Kitchen Ranges
C34s 901 over pilot burns with soot - Wolf Range Kitchen Ranges
Why does my pilot light keep going out when heating is on ?
Water heater and house heater are sharing the same vent?
Then vent is bad, and heater is pushing combustion by-product down into the water heater and blowing out pilot.
Call technician immediately to avoid CO poisoning.
Look for black soot on top of water heater... test the vent:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#vent
Read about Carbon Monoxide poisoning: symptoms and first aid
http://waterheatertimer.org/Is-natural-gas-clean-burning.html
Gene
Oct 08, 2014 | Water Heaters
Turn on the pilot , when turn on the burnes evreting off
Hi there.
Ensure that the gas supply pressure is sufficient and the thermopile should be free of soot or any form of dirt, also the pilot flame should heat up the thermopile efficiently.
Regards.
Jul 12, 2011 | American Range AF40 Deep Fryer
The pilot light takes a long time to light, once lit it barely has but a small blue flame, what is the problem?
Ensure that the unit receives the standard gas pressure as rated on its nameplate.
Pilot orifice may be partially plugged or has some dirt on it, You have to dismantle the whole pilot assembly to gain access in cleaning the pilot orifice. Be careful not to enlarge the orifice bore in cleaning for that will only result to poor pilot flame quality.
The thermopile must be free of soot or soot form of dirt in order to detect the right amount of heat from the pilot flame so that it could also, in turn generate the right amount of voltage needed by the gas valve for pilot and burner operation.
Regards.
Jun 23, 2011 | Vulcan EF3 Deep Fryer
My dyna glo nat. gas heater piolet light is to long and when you turn it on low it is burning on high
Sounds like your heater needs a service, is there any sooting around the pilot if so have it serviced asap
Dec 15, 2010 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
My pilot flame is too high . What could be causing this ?
If it's an Atwood and just recently started burning a yellow, higher flame, look closely at side of fitting where the pilot tube is attached to mounting bracket. You should see a very small hole in the side of that fitting. Take a paper clip, or something as small in diameter, and poke around inside that hole to clean it out, or shut pilot off, and use compressed air, to blow into it, to clean it out. Now re-lite your pilot and see if you have a nice blue flame now. That little hole is your air mixture for the pilot and sometimes debris clogs it, thus causes (rich mixture) yellow/red flame, which will also cause soot build-up in the chamber, or even on outside cover. Let me know if that cures it.
May 09, 2010 | RTO Atwood Water Heater - 6 Gal LP
Pilot light does not stay lit
check that pilot flame is in contact with the thermocouple the small copper cylinder if not properly burning against adjust if flame is good and the therm/coupl is not covered in soot(wipe clean if has build up)thermocouple gone bad replace
Oct 28, 2009 | Goodman GMS90703BXA Heater
Pilot keeps going out
check thermocouple small copper sealed tube that flame burns against flame should be burning on tube when starting or as pilot lite,if has soot wipe with rag if adjustment good and clean replace thermocouple
Oct 27, 2009 | Procom QL300TYLA Heater
Propane kitchen-oven ''whoofs''
Propane burns very dirty,I bet the burner and pilot are clogged with soot.In techinical terms the sound your hearing is blowback.If you check the burner/pilot you will likley see black soot,remove them and clean with soap and water.
Mar 16, 2009 | Ovens
Oven makes rushing noise when turned on
propane gas right?if so what your hearing is blowback,propane burns very dirty therefore obstructing the air/fuel mixture in the pilot/burner.you need to clean out the pilot and burner.gain access to the burner there should be a couple of screws and use oven cleaner to remove the soot.use gloves its messy.let me know happy new year!
Dec 27, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Kitchen Ranges Logo
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
Dan Webster
Dan Webster
Fred Sops
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
