Question about Murray Garden
Can a riding mower starter lose torque? - Murray Garden
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 96 Answers
Basically no.I am going to assume your mower is slow or very hard to crank over with a good battery, if this is the case, one of two things, either a week solenoid or the valves need adjusted but 99% of the time the valves need adjusted. They are not opening soon enough causing the compression in the cylinder to reach high levels too early in the stroke. Hope this helps.
Posted on Oct 20, 2013
4 Suggested Answers
  • 79 Answers
SOURCE: riding mower will not start
Hi
Starter drive is stuck. Clean by spraying brake kleen on starter drive and blow drive with air. Might
have to remove starter to clean. Check for missing cogs on starter drive.
Posted on Apr 07, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
bbreton
  • 437 Answers
SOURCE: Snapper Hi-Vac riding mower that won't start with starter
You may need a 300cca battery, an ignition switch or a solenoid to get things going again. I also would check to make sure the starter gear has not locked in the flywheel teeth; it will burn up the starter. You should be able to go to the snapper website and put your model of mower in and find the parts and diagrams you need.
Good Day.
Posted on Oct 26, 2009
John deere riding mower wont turn over unless plug is out
IF you have to remove the spark plug to get the engine to crank, check to see when the motor is in the compression stroke and go just past that point and try again to see if the motor cranks with the spark plug back in. 3 of 4 piston motions are not related to compression. If it does not move then the starter does not have enough torque.
May 13, 2015 | John Deere Garden
What makes a mower lose fire?
need fuel, spark and air. Make sure air filter is clear. Best way to test this is leave it off while you try to start (or restart??). For spark, easiest way is to spray starter fluid in the carb. If it starts, you have a fuel problem. If you havent lately (or ever?), change the fuel filter.
Jun 19, 2014 | Craftsman YT 4500 54" Kohler 26 hp Gas...
Is there a seal behind starter?
You have a torque conventer seal out.
May 11, 2014 | Ford 555 backhoe
Why won't the starter work on the engine but will off the engine?
check all your wire conections on the starter the battery and the selinoid it sounds like a bad or lose ground conection to me
May 03, 2014 | John Deere 420,1020,2010,2020,2510,2520...
My yard machine wont start, i have spark, fuel, and compression. yes there is gas in it. has oil. starter cranks and I pulled the carb off and cleaned the float and everything. the starter almost looks...
Probably not the solenoid they usually work or they don't. Slow cranking could be due to weak battery or bad connections, check those. If all is ok starter motor could be bad. Always check simplest first.
Oct 06, 2010 | Yard Machines 155 Torque Briggs Stratton...
Only click when i turn the key battery is new
A couple of quick questions.
1. How new is the battery? Reason I ask is the battery can lose the voltage quickly, even though it shows good voltage it may not be producing high enough cranking amps to turn the engine over. The clicking could be coming from the starter bendix hitting the flywheel but not enough of cranking power to engage for engine start.
2. The starter solenoid is most likely the problem if it is clicking every time you turn the switch over. The battery sends power through this to engaged the starter which turns the flywheel. Sometimes these are located under the seating area, which can be a little hard to get to. Just follow the + cable from the battery and you will lead into it. God Luck and hope the $15 solenoid fixes the problem.
Jul 27, 2010 | Yard Machines 155 Torque Briggs Stratton...
Need wiring diagram
There is a safety switch under the seat as well as attached to the clutch pedal
Jul 26, 2010 | Yard Machines 155 Torque Briggs Stratton...
I was riding the tractor mowing shut it off to get lunch returned 1 hr later would not start. I bought a new battery and had the starter checked all good still wont start. I get a click when i turn the key...
The starter solenoid sounds to be bad. Follow the + cable from the starter and it will lead to the solenoid. This is usually about $10. The battery produces power to the solenoid which then produces power to kick the starter over. The clicking is the contacts in the solenoid you are hearing.
May 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
My yard pro tractor will not start I think its the starter.. how can i fix this
The most practical way to accomplish this is to simply remove the starter. Then apply battery voltage to the starter just to make sure that it IS the starter. Be Careful, the starter has a lot of torque and will jump when proper voltage is applied. I say test the starter because you may have a seat safety switch or other safety feature that will not let the starter work.
Hope this helps!
Dec 07, 2009 | Garden
Instructions to replace starter on JD RX75 lawn mower engine
DID YOU TAKE THE TOP COVER OFF THE MOTOR? AND THERE IS ONLY ONE WAY THE STARTER GOES OTHERWISE IT HITS THE SIDE OF THE ENGINE.. i REPLACED MY STARTER FEW MONTHS AGO.. tHE STARTER WIRE HAS TO BE ON THE OUTSIDE TOWARDS THE OUTSIDE BODY....
Sep 05, 2009 | Garden
Garden Logo
49 people viewed this question
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
