Question about Garden
Charmglo CGL300TQ Says it is designed for
Charmglo CGL300TQ Says it is designed for propane only. I am well acquainted with propane and propane stoves. Usually to adjust the air there is a small cap that covers a cut out in the feed tube This does not have it . Some you can adjust the coupling hook up. This one does not appear to be that style Anyone have any info on adjusting the air intake as the flame is very high and burning yellow Any info wiuld be appreciated
I want to convert from LPG to NG
see a charmglo dealer we have no information about conversions here
Jan 21, 2018 | Heating & Cooling
I have a Charmglow CGL300TQ gas heater and it will not stay lit over night. How do you figure it out and where can I buy parts for it.
Contact Charm glo thru their website and ask tech support .I do not recommend DIY for gas appliances as 1 mistake is deadly
Dec 02, 2016 | Heating & Cooling
Orange flames on two Blue-Flame heaters, dual fuel, currently running propane.
Could be that the burner needs cleaning dirt in the burner tubes
Nov 02, 2012 | Blue Flame Heating & Cooling
I have a charmglo electric fireplace blower works but there is no heat is it the thermal cutoff and if it is what do I replace it with and also can it be put in backwards
More than likely it's the Thermal overload circuit or the heating element has given up the ghost.
As I just told one other questioner. These types of electric fireplace heaters were not designed to run for long periods of time. Their heat output is not much more than a blow drier. However, this is not just a problem with CharmGlo, it's with all the manufacturers.
Here's the problem ... The heaters work by taking in cool air, heating it and sending it back out via the blower. Over time, the heating element and/or blower become clogged with dust, lint and/or pet hair. This makes the heating element work harder and it over heats. Either burning out the heating element or the thermal overload switch or both.
You can try cleaning the heating element with a vacuum that has a hose and a brush attachment. While you're at it clean the blower fins and motor. Consult your Owners Manual to see how to access these parts, as they are under firebox, behind the metal grill on the bottom of the firebox, so to speak.
Feb 05, 2011 | Heating & Cooling
I have a Charmglow propane heater model CGL300TQ with a bad fan. Where can I find parts for this stove and does Charmglow have a website for parts?
Depends what is actually wrong with fan, if tis the blower barrel part you can by replacements but if its the fan and you van't find manufacturer try an commercial or indutrial fan place to match the one you have be careful to make sure that it is electrically compatible and that it will connect to heater safely and do as old fan did as fan speeds on heaters can be important
Nov 17, 2010 | Stoves Heating & Cooling
Charmglow model cgl300tq. cannot seem to get enough gas to make ignition! i keep pilot inlet tube clean. how can i tell if it is the regulator. it is definitely a gas flow problem!
You will need a manometer to determine your gas pressure, the amount required is posted on your appliance. Take both a static and dynamic reading on the inlet side of the gas valve. If it is not high enough consult a plumber. If it is take a reading on the manifold side. If the gas pressure is too low again consult a plumber. If it is within spec check orifaces and burner tubes if any for debris and spiders.
Mar 06, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Our charmglo ventless fireplace pilot will not stay lit. It started to go off including the pilot lite. Where can we find replacement parts for this problem?
I have the same problem with my Charglo fireplace. The propane company checked preasure and they even replaced the regulator. I am very disappointed with this and am afraid to use it. I have contacted Charmglo in the past and they were useless.
May 18, 2009 | Home Decorators Collection Charmglow...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
