Question about Motorola Mobility H390 Bluetooth Headset
My bluetooth head set is flashing when I go to charge it up. It is suppose to charge with in two hours but it just keeps flashing and dosn't seem to charge.
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
How to get my new Bluetooth set-up
So, what else can I tell you. You yourself have discribed that your headset is defective. So, being a new device, return it to be changed for a new one.
Jun 03, 2014 | Apple Cell Phones
Charging battery
Sometimes if charged too long or your not around when the light does go off, after awhile the battery looses its charge. when that happens the charger will start to charge again and it will seem that it isn't working right or charging. in your instruction booklet it should tell you how long it should take to charge. some say 45 min some say hours. set a timer once you find the time recommended for your device, once it goes off unplug if light is off. good luck
Dec 07, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
My voyager pro+ keeps flashing red when charging. However when it is unplugged with charger, it does not work at all. Please kindly help.
If it is flashing red like it is supposed to be charging, and it is not, look at the connections. Are they worn, not connected properly? Make sure that the AC charger is plugged in firmly. If this still fails to charge your bluetooth, it may have to do with the bluetooth itself. If this is still under warranty have it replaced. Try a different outlet or charger to see if that is what is not working.
Good luck from Headsets Direct!
Jun 19, 2011 | Plantronics Voyager PRO Bluetooth Headset
Recently i have purchased Motorola S9 blutooth head set. Kindly let me know what type of motorolla charger to be used 1.5amp or 2 amp since there are 2 chargers available. And also while charging, within...
Bluetooth headsets, like many portable devices can be charged on a USB port on a computer, which supply less than 1A, so either charger would be suitable.
Looking at the manual, a full charge should take two hours, so half an hour seems a little quick.
Perhaps it was part charged?
You could see if you can listen to music for six hours on a charge, and if so how long it takes to charge then.
The manual can be found here.S9 user guide - Motorola
Feb 14, 2011 | Motorola Mobility S9 Headphones
Connecting bluetooth head set
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
Mar 11, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
I cant get my bluetooth head set to work on ps3 i dont know how to put the blue tooth into pairing mode i dont have instructions for the bluetooth. it is a ps3 bluetooth bought from argos
Hi, i had this same problem. really annoyin. first make sure you charge the headset fully. then while keeping the slidy mouth piece closed hold down the centre button untill the blue light comes on and will start flashing. your ps3 will then be able to find it. the defualt pass code is 0000
Sep 16, 2008 | Video Game Consoles & Games
Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
Nov 27, 2007 | LG Jabra A210 Bluetooth Adapter for...
Motorola Mobility H390 Bluetooth Headset Logo
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
