Question about Building Materials
During installation, when I press large "t" button, door does NOT go through its four cycles
    Problem Solver:
  • 14 Answers
If this is an Horman opener unplug it so that the limits reset then plug in the opener and press the T button again and see if it goes through it's paces
Posted on Oct 27, 2013
Cannot use the up and down arrow buttons to change wash cycles
X-Stream Wash Installation and Operation Manual (PDF)
dukemfg.com/wp-content/.../3/.../115152-Manual-X-Stream-Wash.pdf
Installation and Operation of X-STREAM WASH. 2 ..... Duke Manufacturing Co. cannotassume liability for .... be placed in the wash tank during a wash cycle. .... Down Arrow Button Pressing this button, while not in the temperature set point mode, will display the time ... Use the Up or Down buttons to change the temperature.
[PDF]HYDRIM L110w - SciCan
www.scicanusa.com/site/scicanusa/assets/pdf/scican_hydrim_l110w.pdf
Thank you for selecting the Hydrim L110w instrument washer. The Hydrim ... Contents of this manual are subject to change without notice to reflect changes and ... Down Arrow - used to adjust a value down, or to move between screens in a menu .....button is pressed, the cycle is aborted and cannot be re-started.
[PDF]using the timetech timer tts-4/tts-8 (mfg ... - AJ Antunes & Co.
ajantunes.com/portals/0/productdocs/1010878.pdf
The TimeTech Timer uses four or eight timing channels to track four or eight different ...Use the Up and Down arrow buttons to select the desired Time Stage and .
Jan 20, 2016 | Washing Machines
F7 on my hot point. Washing machine
This error code indicates that the motor is having difficulty turning.
Are the shipping bolts removed?
All four (4) shipping bolts and the plastic spacers must be removed from the rear of the washer before you operate it. Each unit is shipped from the factory with four bolts, which are designed to secure the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration or error codes. See the Installation Instructions for details; find them by entering your model number in the search tool below.
Were you washing a very large load?
The washer may be overloaded for the cycle you are running. Remove a few items from the load. See the Cycle Guide in the Use and Care guide for loading suggestions for each cycle.
To remove the error display, press Power once. Then press Power again to restart the washer.
If pressing Power does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
Apr 22, 2015 | Washing Machines
Indesit DIF04UK: Help with problem determination please?
Modifying a wash cycle in progress:
If a mistake was made during the wash cycle selection process it is possible to change the cycle, provided that it has only just begun: open the door, taking care to avoid the escaping steam, and press and hold the ON/OFF button; the machine will switch off with a long beep. Switch the machine back on using the ON/OFF button and select the new wash cycle using the SELECT WASH CYCLE button; start the cycle by closing the door.
Dado
Sep 08, 2014 | Indesit Dishwashers
Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
Nov 07, 2009 | Washing Machines
F-26 flashing
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door
switch is open while the door is locked for more than
5 seconds.
Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Push POWER.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
procedure.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
The door is locked, no light on, washer won't run
Is the power cord plugged into a grounded 3 prong outlet?
Plug power cord into a grounded 3 prong outlet.
Are you using an extension cord?
Do not use an extension cord.
Has a household fuse blown, or has a circuit breaker tripped?
Check to see if a household circuit breaker or Ground Fault Circuit Interrupter (GFCI) outlet has tripped. If so, reset the circuit breaker or Ground Fault Circuit Interrupter. If the washer is on a fuse box, check to see if a fuse has blown and replace it, if necessary. If the problem continues to occur, call an electrician.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on. The washer will not operate properly with only one incoming source of water.
Is the water inlet hose kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove the inlet hoses from the washer. Remove any accumulated film or particles. Reinstall hoses, turn on water and check for leaks.
Is the washer in a normal pause in the cycle?
The washer pauses for about 2 minutes during certain cycles. Allow the cycle to continue. Some cycles feature periods of tumbling and soaking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look closed, but may not be latched. Open the door and close firmly.
All four shipping bolts must be removed from the rear of the washer before you operate the washer. Each unit is shipped from the factory with four bolts, which are designed to protect the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration, error codes and possible machine damage.
Has a cycle been selected, but Start has not been selected and held for 1 second?
Press and hold Start for 1 second.
Is the Control Locked status light on?
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Is the Delay Wash status light on?
Your washer will start after the selected hours of delay are completed.
Was the door left closed after the last cycle?
The washer door must be opened and closed again to start a new cycle. If the door is not opened between cycles, the washer may not start.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet has no power
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Building Materials Logo
42 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
