Question about Rheem RTG-66DVN Direct Vent Natural Gas
Error code #66 - Rheem RTG-66DVN Direct Vent Natural Gas
  • 68 Answers
Water Bypass Valve malfunction. Hot outlet water temperature is above or below set point on Remote Control.
but 99% of the time it is the PCB Board, you will have to contact rheem they may send you a new circuit board.
Posted on Nov 11, 2013
What does error code 13 mean?
1) Copy following links for Rheem tankless error codes
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-Error-code-13.pdf
2) Maintain water heater as shown in product manual to avoid common error codes.
Dec 28, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
Tip
How to repair a defektive ESBE Type 66 Electronic Motor Actuator 12001414
symptoms:
the actuator motor stops working
after manual operation it start to work again
sporadic failure
problem: cracked solder joint around the microswich pins on PCB
remedy or solution:
resoldering of the cracked joits
on Mar 04, 2016 | Water Heaters
Rheem rtg-66dv error code 12
Troubleshoot and error codes following link:
http://waterheatertimer.org/pdf/RTG-error-codes-3.pdf
Not getting gas, low gas pressure, air in gas line, igniter not aligned with burner, wires disconnected, unit not grounded ...
Nov 10, 2017 | Rheem RTG-66DVN Direct Vent Natural Gas
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
Oct 19, 2012 | Rheem Paloma Tankless Water Heaters...
What does an error code 66 mean on a noritz Model N-0751M
http://www.noritz.com/u/pages_from_field_manual_2010_12_09_pdf__adobe_acrobat_professional.pdf
The Noritz field manual says that error code 66 is Bypass Water Control Valve failure. Call support at 866-766-7489 with your model #, serial # (both on the unit face plate), date of purchase, to see if the valve can be replaced under warranty.
Jul 14, 2012 | Water Heaters
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Error-code-13.pdf
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Aug 12, 2011 | Rheem RTG-66DVN Direct Vent Natural Gas
Code c4-13
Before calling service technician, open following link for Rheem troubleshoot resources including error codes, Rheem chat, and possible manual:
Error code C4 13 is bad oxygen sensor, inadequate incoming air supply, or bad venting. Also bad PC board, or internal wiring, or temperature set too high, damaged burner parts.
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Tankless require yearly maintenance to combustion chamber and burner parts.
Prescribed maintenance can correct some of the issues in error code 13.
Jun 25, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
Error code 13 (air flow) tankless H20 Rheem
Have 2 of these Rheem units in my house. Both had this same error code within 30 days of each other. And my neighbor has 2 units as well - and guess what - 2 months after mine stopped working because of the code - so did theirs. It is not something that can be fixed. It is a manufacturer's defect - and it looks like Rheem has yet another class action on their hands (like the one for the RTG - 74 PVN). They need to do a recall to repace these units.
Jan 17, 2010 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem Pronto RTG-74 error code C4
Error code 13 is "oxygen depletion sensor" activated.
The first number is a sequence indicator.
If you need the training manual I have it and can send it to you.
I got Rheem to send it to me a while back and it is a big help when working with these units.
It covers th RTG-42, 53, 66 and 74.
Apr 29, 2009 | Rheem Tankless Hot Water Heater...
Rheem RTG-66DVN Direct Vent Natural Gas Logo
322 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
