Ferguson Stereogram / Radio Model 3362 loud humming from left hand speaker
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: get loud hum from both
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on May 23, 2011
Humming noise
Possibly a bad cable or bad ground or bad outlet?. Easy solution, try a different outlet and see if the hum still exists. Also, make sure your speaker cables are NOT run parallel along with, or close to any power cables, Speaker wires can and will pick up AC "Humm" noise.
Apr 23, 2014 | Edifier Audio Players & Recorders
Viking spa speaker issues
sounds like something got wet your getting a 60 cycle hum from electric disconnect radio or replace radio hum is coming from amp in radio
Mar 15, 2014 | Pool & Spa
Where would i find the chassis number on a massey ferguson 3115
Climb up into the tractor's seat. Look below the lower left-hand side and lower right-hand side of the steering wheel panel for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to one of these areas of the steering wheel panel.
Serial Number Plate:
http://old20tractorparts.com/mf-165-tinwork-parts/1356-massey-ferguson-165-serial-number-plate.html
Inspect the left- and right-hand sides of the tractor's main frame. Certain older Ferguson tractors have the serial number stamped to a plate on the outside of one of these areas of the main frame.
Inspect the top of the transmission housing for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to the top of the transmission housing.
Jan 27, 2014 | Aprilia Pegaso 650 i.e Motorcycles
Loud hum on mirage omni s8
need to replace the amp assembly...common problem on this model.
Dec 04, 2013 | Mirage OMNI S8 Speaker
2001 FLHT, tried jumping bike and now speakers hum
Hi Burgh, you might want to give Harmon Kardon a call on this one, but there are radio fuses 1992 and later Touring Models, fuel pump fuses and relays will be behind the right side panel, everything else will be behind the left side panel to access fuses pull back on the front two locking tabs and slide the cover up. Good luck.
Apr 16, 2013 | 2001 Harley Davidson FLHT Electra Glide...
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
I have a set of wireless speakers which when
The hum is generated by incompatible Ohmage
one is 8 ohm the other 16 and it is overdriving.
If that does not appear to be the case then there is some lack of shielding on the plugs to the JVC.
But i would punt for the first option
Sep 05, 2009 | Televison & Video
Mains hum on Ferguson R121 DAB radio
wrap aluminum foil around the power cord
Jul 19, 2009 | Audio Players & Recorders
Speaker a and b have humming noise
If it's a loud 60 cycle hum stop running it and have it serviced. This hum can be a shorted output which can send out 50 to 60 volts out to your speakers damaging them.
Jul 17, 2009 | Audio Players & Recorders
I recently bought a 2005 toyota corolla verso(irish model) is there any way i could get my hands on the audio wiring diagram because i want to fit a parrot bluetooth handsfree kit
2005 Toyota Corolla Car Stereo Wiring Diagram
Radio Constant 12V+ Wire: Blue/White
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Power Antenna Wire: Black
Front Speaker Size: n/a
Front Speaker Location: n/a
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: n/a
Rear Speaker Location: n/a
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
rate pls
Dec 10, 2008 | 2005 Toyota Corolla
52 people viewed this question
 Grubhead
Grubhead
