Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Our Panasonic Viera TC-32LX700 displays "Channel not found". We have unplugged it and gone through the initial set up all over again. It is connected to am antenna, not cable. After the display, the screen eventually goes black, although the tv itself remains on. Any thoughts?
  • michelle adkins
    michelle adkins Mar 10, 2015
    I have this issue as well but through cable box.
I have this issue as well but only on the video channel which connects to the cable box to view cable tv. No blinking lights that I have ever seen, and does not happen on any other of the settings (HMI, comp Etc)/
Posted on Mar 10, 2015
  • Official Brand Answer
  • 350 Answers
Try relocating the location of your antenna or changing the direction it is pointed. Once this is changed, select PROGRAM CHANNEL from the SETUP menu and set ANT IN to Antenna before selecting Auto to start the programming process.
Posted on Oct 22, 2013
4 Suggested Answers
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Posted on Oct 07, 2007
skotkolr
  • 558 Answers
SOURCE: Panasonic Viera
vga board is bad ot the components on it are blown out.
Posted on May 08, 2008
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
Tip
Panasonic TC-32LX70 Manual Download
Download Panasonic TC-32LX70 LCD HDTV Manual
Would you like to review the features of the Panasonic TC-32LX70 LCD HDTV?
Have you lost your Panasonic TC-32LX70 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic TC-32LX70 LCD HDTV Users Guide?
Follow this link
(& click FREE) to download a pdf version of the Panasonic TC-32LX70 LCD HDTV documentation.
I hope that helps.
on Jul 13, 2010 | Panasonic TC-32LX700 Television
My Panasonic TC-32LX700 has decided it doesn't recognize any channels. No matter the station, the screen reads "Channel not available." It is hooked up to an antenna, not cable. I unplugged it and then...
If you searched for active channels and got no results, the antenna may not be adequate or may not be properly oriented. I have to use an amplified antenna even though I am located in a major metropolitan area
Oct 19, 2013 | Panasonic TC-32LX700 Television
TC-32LX700 WON'T TURN ON
My Panasonic does this periodically. I have to unplug it for a moment and then plug it back in. Sometimes it will turn right on, sometimes I have to press the on/off button. I wish I knew the root cause.
Nov 10, 2012 | Panasonic TC-32LX700 Television
I'm trying to connect laptop to Panasonic Viera TC-P46S30 using VGA-HDMI converter. I'm getting 'No signal. ...' box displayed on TV. How can I fix it.
on your computer, go into your vga graphics driver and hit properties, set it for dual and hit apply. close the box. then go to the graphics,options, look for dual. make sure the wire is tightly in your tv and computer. switch your tv to vga. it should be lit. then you should see your desktop on your tv screen.
Dec 11, 2011 | Televison & Video
Firmware tO Correct TC-32LX700 Turn On/Turn Off Problem?
when I put SD in tv show 0013 error what is the problem??
May 20, 2010 | Panasonic TC-32LX700 Television
Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
Sep 14, 2009 | Panasonic TC-32LX700 Television
Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Jun 24, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
181 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
