Element tv model #eldfw406 power no picture - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 36,385 Answers
Possible internal power supply failure
Posted on Oct 19, 2013
My element tv has no picture. (it can be seen with flashlight test) will a power supply repair kit fix this issue?
This is usually not the power board. the LED strips fail and you have 55 LED bulbs in the back light. It is not an easy fix because the display is glued to the bezel and if you don't take extreme care when working on it, you crack the LCD display.
Jan 19, 2017 | Element Televison & Video
What is wrong with MY ELEMENT ELDFW406? it POWERS ON BUT ONLY HAS A BLUE SCREEN, NO MENU NOTHING.
Tuner fault. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 30, 2015 | Element Televison & Video
I have a 40 in element TV model ELDFW406 that wont turn on . No red light either. . I replaced the power supply board and still nothing. What else could it be?
Here's the owner's manual (http://www.elementelectronics.com/support_docs/40le45s/40le45s_manual.pdf)...Try the troubleshooting on page 21...if that doesn't help, you just gotta run it down...take a voltmeter and check the wall outlet for power(it's the simple stuff that gets me), then the power cord to the board...there has to be a fuse in the line somewhere, which is what I suspect...if you have power to the board, and power out of the board(usually at least a couple of different voltage levels), then you can move on to the other boards...but you shouldn't get that far, the red light is the first thing to come on(get power)...
Jan 01, 2015 | Element Televison & Video
Element tv dark no picture
This is a very common issue with that model. There are filter capacitors on the power supply board that fail and keep the back light power section from starting up correctly so you get no picture on the screen. The FLX-1910 uses the same power supply board of the Polaroid TLA-01911, below is a link to information showing how to repair this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
Nov 08, 2012 | Element Electronics FLX-1910 19 in. LCD...
Element tv turns on then goes off or freezes
That is a common indication of a failure in the power supply board filter capacitors. When the filter capacitors go out the voltages coming from the power supply fluctuate and cause all sorts of picture and power up problems. That model is actually made by Funai and is the same as the Polaroid TLA-01911c TV. They use the same power supply board which is the 200-000-xxxxtitx Here is a link to a repair guide for the Polaroid model that will be the same as for your Element TV.
I hope this information helps you out.
BuddyMc
Sep 30, 2012 | Element Electronics FLX-2210 22 in. LCD...
My screeen has gone white on my tv how do i fix it on my element flx-2210 tv
White screen only / no picture is a sure sign of a failure in the power supply board. Your TV is getting power to the back lights but the control board voltages are not getting through so it is not displaying the picture right. This is an easy repair to do, you will just need to replace the filter capacitors on the power supply board. This Element model is actually made by Funai and is the same as the Polaroid FLX-01911c TV. Here is a repair guide for that model that will show you what needs to be replaced to get your TV back up and running again.
I hope this helps you out.
BuddyMc
Jan 30, 2011 | Element Electronics FLX-2210 22 in. LCD...
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Element 26 model ELCHS 261. The tv powers up ok but
has problem on the board.the solder is loose or loose solder
Jul 18, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
