Question about Ampeg BA115 1x15' Bass Combo Amplifier
How do you read serial number on ampeg ba115 - Ampeg BA115 1x15' Bass Combo Amplifier
Ampeg b5r rack head squeals with low frequencies. when i wiggle the internal cable to the speaker out i preforms fine until i travel with it. plugging into an ampeg svt 610hlf classic
Sounds like you have a loose connection. Try re-soldering the
internal connection. and check the wire for breaks. it may be the cause of your intermittence. Good Luck!!
Apr 21, 2015 | Ampeg Music
How to check date of production by serial number
Ampeg' website: Welcome To Ampeg
There are also numerous forums on this topic.
Good Luck!
Jul 19, 2014 | Ampeg Music
My Ampeg Ba115 will not turn on
Did you check the fuse? and power cord is good?
Dec 06, 2012 | Ampeg BA115 1x15' Bass Combo Amplifier
I have no sound. Headphone jack is working. Speaker is not. Need help troubleshooting.
With no leads connected to speaker, use an ohmmeter to check resistance of speaker. If NOT less than 10 ohms, you be replacing the speaker. Also look for loose speaker wires. More than that and is will require repair in the shop.
Aug 21, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
Loud humming buzz when I turn it on
Failure, likely in the power amp causing overloading of the power supply and dragging one power voltage into the range where the ripple voltage gets to the speaker. This is very ******* the speaker as it gets high DC current and can burn the voice coil. Slight chance that a filter capacitor has failed. In either case repair is needed.
Aug 11, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
Power to my Ampeg BA-115 quit suddenly whilst playing. Back of amp was hot - there was a crackle immediately before it quit. I allowed it to cool down and then turned it on, but it was dead.
Here is your schematic. Likely the fried components are visible.
http://elektrotanya.com/ampeg_ba-115.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
When repairs have been done, start this up using a 100 or 150 watt incandescent lamp in series with the power cord to act as a fuse... There likely are several components blown and you may not get them all the first time. The lamp acts as a resettable current limiting fuse so you don''t blow out what you just replaced.
Aug 05, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
Ampeg BA600 115 combo power cuts in and out!
Broken cable jacks are most common problem. Cracked circuit boards and bad soldering is second on the list.
Jul 14, 2011 | Ampeg BA600 115 1 x 15 Bass Combo
The CD input on my Ampeg BA 115 works, but the 0db and -15db inputs don't. This happened immediately after using the CD input. Quick fix, or repair shop? Thanks.
Sounds like a repair shop job to me. Inputs on a amp have resistance thus there must be a issue inside hence 0DB to 15DB if you go higher well that input thus would not work anymore.
Repair shop would be your best bet for this amplifier. Quick Fix would be unplug it and plug it back in and praying it resets but that won't happen.
hope this was of some help, if not I am sure others will chime in with there 0.2 cents.
Regards
Rulds2008
Jun 15, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
My ampeg BA115HP is dead. I suppose it is the fuse. Where is the fuse located?
it's the black thing sticking out of the circuit panel on the back of the amp
May 22, 2011 | Ampeg BA115HP 1x15' Bass Combo Amplifier
All the inputs on my ampeg bass amp are not working even the RCA input is not working. the amp still turns on
If none of the inputs work, then you may have lost part of the power supply. DO NOT go into this amp under any circumstances !!!!...there is enough voltage in here to kill you crispy !! I would strongly recommend that you take it to a respected repair shop that specializes in guitar amps. Possibly visit the ampeg website for an authorized repair center. It might cost a few bucks, but the Ampeg is highly sought after by musicians everywhere !!!....thanks... Rob
Sep 01, 2010 | Ampeg Classic Series Svtvr 300watt Tube...
Ampeg BA115 1x15' Bass Combo Amplifier Logo
79 people viewed this question
Top Ampeg Music Experts
Vito Vacirca Jr.
Maxx
Level 1 Expert
Robert Jenkins
Are you an Ampeg Music Expert? Answer questions, earn points and help others
