Question about HP OfficeJet 6210 All-In-One InkJet Printer
Cartridge door shows open but it is shut ?
The message keeps soming up since I changed the cartridge. I ahve swirched off and and tried taking out the cartriges etc
Very simple,please remove ur cartriges and swicth off the system and now fix and restart ,if problem persit,get back to me
Posted on Sep 27, 2007
SOURCE:
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Can't get HP PSC 2530 to accept re-filled catridges! Both are full but it keeps telling me to remove and check right-hand one; can't by-pass or override the message.
Hi
In order not to have error messages in your printer
You need to remove all the air bubbles from the cartridges
the best way when you do it alone is bu using refill clips
check here the right method
Hi pls vote us to keep us alive
Nov 08, 2010 | HP PSC 2350 All-In-One InkJet Printer
What is the cause of my printer o be saying change cartrige when i already change it
It may be some reasons:
1. Cartridge incorrectly changed. Just be sure to remove and set the new cartridge correctly.
2. No good connection. Sometimes ink spills on the cartridge connectors OR the protective plastic still set on the cartridge. Clean the connectors with a soft cloth and be sure to remove the plastics - see installation guide on cartridge.
3. No procedure was done. To change a cartridge correctly, some printers require a procedure for it, be sure to read the user manual how to change cartridge.
Other non-common issues: bad new cartridge, faulty printer, software or firmware glitch, etc,
Apr 15, 2010 | Brother MFC 420CN All-In-One InkJet...
Keep getting 5100 error message--eratic
PLUG IT OUT FOR ABOUT 3 DAYS.AFTER PLUG IT BACK IN AND IF YOU ARE STILL GETTING ERRO MESSAGES CALL 2489921 OR 2849921 AND I WILL GET YOU SOME ONE TO SOLVE YOUR PROBLEM.
Dec 15, 2009 | Canon MP610 Photo All-In-One Printer
Black Cartridge
Hi - If you are saying that the right side cartridge is the black cartrige that you have replaced, then I have two suggestions that may help. If the cartrige is a new HP genuine product I would take it back. If not, I would return the cartrige you have and buy a genuine HP for the printer. Though an expensive solution, there is always a chance of defects from either party. The remanufactured or refilled cartrige will have a date on it. The circuit board on these can wear out and then not be recognizable over time. Second suggestion if you have not already done this, a cotton swab or Q tip dipped in distilled water(damp only) to wipe down the circut board on the printer where the cartrige will connect to it, may help. Turn off the printer to do this. Make sure it is dry when you turn it on and reinstall the new cartrige. Hope this helps.
Jul 07, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Cant get re-filled ink cartrige to work
It sounds like whoever refilled the ink cartridges did not reset the counter in the cartridge, so it thinks that it is still empty.
May 23, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
Get message error change cartriges the cartriges are new
All cartridge installation and level reporting is done through the printer itself, not the software. You should ensure the X125 has the cartridges installed in stand alone mode first. To do so, open the lid and remove the cartridges. Then unplug the power cord for one minute. Reinsert the cartridges, connect the power cord and close the lid. When the lid is closed, the display will ask you if "New" or "Old" cartridges were installed. If new, align the cartridges, if asked to do so. If this still presents you with a "Change Cartridge" message or something similar, please try a different cartridge.
Apr 22, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Dell 926 printer
Dell cartridge are quite expensive, and refilled and non original cartridge are often not accepted by Dell printer. If you use non original cartridge often you keep getting this message unless you replace both cartridges.
Be also careful also if you use refilled, sometimes refilled can leak all over the inside of your Dell printer right when ink is coming to the end.
In your case try replacing both cartriges at the time, this usually clears the error.
A suggestion: Dell small inkjets are sold at a price often inferior to the cartridge set price, and now you know why, ask the price for a new Lexmark, HP, Epson,Brother, Canon etc. next time you have to replace a cartridge set, it may be worth buying a new printer.
Apart small inkjet sector, Dell produces excellent laser printers, computers, laptops and more.
You can read more opinions on small dell inkjets here or using google.
Aug 18, 2008 | Office Equipment & Supplies
HP OfficeJet 6210 All-In-One InkJet Printer Logo
52 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
