Question about Sony RDR-VX560 DVD Recorder/VCR
Close drive door vcr - Sony RDR-VX560 DVD Recorder/VCR
Why do my vcr eat taps
Every VCR has a transport mechanism that moves the tape-when eject is hit it reverses and winds the tape back into the cassette and closes the door on the tape BEFORE the tape exits the unit.
It is not doing that so the tape gets mangled--bad belts, bad rubber drive wheel etc---all happen with age even if unit is not used much.
Parts for these are getting hard to find--if any questions post a comment here.
SD TECH
Apr 26, 2012 | Philips Magnavox DVD/VCR Dual Player
Zenith dvd/vcr model ABV341 DVD WON'T STAY IN TO PLAY...VCR WORKD FINE
If the door does not close either something ( a coin or anything) got inside or there is a issue with the mechanism= alignment or possible bad part in that mechanism that loads and positions the disc.
A suggestion when door opens try to take a quick look inside with a flashlight to see what you can.
Apr 04, 2012 | Zenith Televison & Video
How to fix vcr door problem?
This is probably not just a door problem. The MECH, that's tape carriage and transport mechanism, is probably in need of alignment/repair. This could be as simple as a belt, of as complicated as a complete realignment, which may be cause for replacement.
What happens when you load a tape?
Mar 17, 2012 | Emerson Televison & Video
Dvd tray will come out to put the dvd in to play it, the door does open
If you meant the door wont close then it canbe that the drive is faulty , might have mechanical prroblems with the drive, might have a faulty motor drive IC with the reverse section not working.
remove and checck the mechanism first before check board, a possible connecctor link faulty or a dry soldered IC can be the fault.
Sep 25, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Dvd door will not close
you need to replace the drive as the spring might be broken.
Nov 12, 2009 | Televison & Video
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
Door on DVD player
The drawer seems to hang up when it sits closed for a while. I found that using a very thin but rigid metal item such as a nail file under the leading edge, allows it to open with the first press of the  open/close button. I load the DVD, press the open/close button and it closes and stays shut.  After I submitted my problem, it occured to me that the reason for the door to continue to open and  close, was the repeated pressing of the button. The door was merely responding to each time it was "called."
Jan 15, 2009 | Sanyo DVW-6000 DVD Player/VCR
DVD player problem
I had the same problem before.  I found a loose rubber ring which drives the door open/close may be the cause.  Use honey wax or candle wax to wax the ring will be most likely to solve the problem.  The only thing is you need open the box by yourself.
Jun 24, 2008 | Sanyo DVW-5000 DVD Player/VCR
Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Dec 22, 2007 | JVC DR-MV7 DVD Recorder/VCR
Tape door wont close
I'm having a similar problem. The camera is a Sony DCR-TRV280. When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down. In other words the mechanism works fine without the tape but with the tape it doesn't. I hope the explanation is clear enough. Thanks
Mar 21, 2007 | Sony Handycam DCR-TRV525 Digital Camcorder
Sony RDR-VX560 DVD Recorder/VCR Logo
22 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
