Question about Bushnell Medalist Rangefinder
Broken wires for battery, need to send in and get repaired
The clip on the door to the battery case is is broken. Where can I get this repaired?
You can visit, or contact a Fuji certified repair centre, close to you. For that use google and ask for repair centre close to or in .... your city.
Before sending the camera in, please ask what the repair will cost you, because it could be more expensive then buying a new camera, with better specs.
Dec 16, 2014 | Fujifilm Finepix S1000fd 10.0 Mp Digital...
Who repairs console, broken battery terminal wire
Most auto electrical shops will be able to do this for you or will have new cables ready to bolt on.
Aug 15, 2014 | Cars & Trucks
Power windows will not work
in most cases the wiring between the door opening , has broken , its in a rubber boot , pop the ends loose and check for broken wires... you can cut it if needed, but you will need to use but connectors to repair the wires. for safety , when you fine the broken wires , disconect the battery before you repair them.
May 12, 2010 | 1994 Jeep Grand Cherokee
My Fossil Blue AM-3662 wristwatch requires repair.
You do not need to send your watch to FOSSIL for repairs. Just find your nearest watch repair shop and ask watchmaker to replace the coil. It will save money as well.
Jan 27, 2010 | Watches
Fuel gauge problem
LOOK FOR A BROKEN GROUND WIRE. TOUCH WIRE FROM SENDING UNIT TO GROUND AND SEE IF GAUGE GOES TO EMPTY. IF IT DOSE THEN YOU'LL NEED TO REPAIR THE BROKEN GROUND WIRE TO SENDING UNIT.
Jan 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My 30gb video ipod will not hold a charge even after I replaced the battery.
You may have a wiring problem if so there is really nothing you can do at home besides send it in to be repaired but it will cost. I am not sure how much though.
Jul 18, 2009 | Apple iPod MA446LL/A MP3 Player
Will not power up. was intermittent...now nothing when power turned on.
If it is still in warranty, it is better to send it for repair with canon or with the extended warranty company.
If it's not in warranty, then you have to send it for diagnostics and repair.
The reason for won't power on may be a number of reasons:
1. Damaged switch that senses when the battery door is closed (or a broken tab in the battery door that presses the switch);
2. Damaged switch that senses when the CF memory door is closed (or a broken tab in the memory door that presses the switch);
3. Defective DC/DC power board;
4. Defective main board
Diagnosctis and repair of this problem requires a repairman with skills and tools to do it properly.
Depending of what is broken and to whom you send your camera for repair, the repair cost may be in in the range of $100.00 - $200.00.
Best regards,
Jul 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camera will not turn on
Best regards,
Jul 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Navman repair
Any electronics repair place or perhaps a camera repair shop should be able to fix it for your. Search google or your local phone book for electronics repair or camera repair. This is a very easy repair IF you are electronics savvy, but not a good first/learning project. This will require either soldering a loose connector back to the board or they may need to find and purchase a new connector to replace the old one if it is broken.
Nov 09, 2007 | Navman ICN510 GPS Receiver
Bushnell Medalist Rangefinder Logo
78 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
