Question about Xterra Fitness UB1.5 Upright Bike"
What does a E1 mean? pops up every time I start my workout.
What does F2-E1 mean in display window
sorry but with no make nor model what can you expect us to do
Feb 23, 2015 | Kitchen Ranges
What is a E1 error
In some Dishwashers it means slow draining time. Can mean the drain hose is kinked somewhere. But other models have other meanings Just type in E1 error and your model it will give you a plethera of information.
Oct 02, 2014 | Dishwashers
Torpedo FN-10195 Magnetic exercise bike ERROR E1
Contacy the makers to see what the error code means.
Jan 10, 2014 | Sport & Outdoor - Others
If I want to recover fast after my workouts, which protein powder should I choose?
Hydrolyzed whey protein is the best pick for you. This powder may mean enhanced recovery and better results from your workouts.
Feb 06, 2013 | Health & Beauty
What is a jump rope workout for a beginner?
I jump for 30 seconds and then rest for 60 seconds and do this about 3-4 times in a row. I do this 3 times a week with a day break between each workout. Once I manage to do this without dying, I'll start jumping for longer amounts of time before taking a break.
Jan 03, 2013 | Exercise & Fitness
I did the self clean on my oven, and now the oven door will not unlock (E1-F5-) pops up onto the oven screen.
Hi
Error E1 F5 means that the control has detected a problem with door latch switch. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether the error has disappeared. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. hope this helps...
Daniel
Aug 28, 2010 | Kenmore 92002 / 92004 Kitchen Range
I have a 22hp intek v twin briggs motor while cutting it just stop now its making a popping noise when trying to start and it wont start just spinning and popping
if its popping out the intake or exhaust,then possibly you have sheared a flywheel key and its out of time,you need to remove the flywheel cover and look to see if this is what happened
Apr 29, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Once I program in my workout and it says to start
Check your manual. If you don´t have one, they can get you virtually any Reebok manual.
Jul 09, 2009 | Reebok RL1500 Elliptical
I have a mio euorfit heart monitor watch. During my workout I
Yes, you definetely need battery replacement.
As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
Find your nearest watch repair shop and ask for battery replacement.
Do not forget to rate, please.
Jan 23, 2009 | Mitac Mio Fit Heart Rate Watch
Xterra Fitness UB1.5 Upright Bike" Logo
530 people viewed this question
Top Xterra Fitness Cycling Experts
John Egan
John Egan
Are you a Xterra Fitness Cycling Expert? Answer questions, earn points and help others
