Question about Linksys CM100 Cable Modem
Linksys CM100 won't turn on - Linksys CM100 Cable Modem
CM100 Cabel Modem refuses to turn on?
You may can try by resetting and re configuring your router but make sure to backup your settings first.
Jan 15, 2013 | Linksys CM100 Cable Modem
CM100 Cable Modem
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router and protect your wireless network from unauthorized access.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 02, 2012 | Linksys Computers & Internet
Can i connect usb port to printer port for network printing
No. The USB port on your cable modem is intended to be used only for connecting a pc to the network. Sorry for the bad news.
For network printing you can use a dedicated print server like Edimax ps-1206u, a great device that make even old printers to get on the network via USB and Ethernet ports it haves
Aug 07, 2011 | Linksys CM100 Cable Modem
I have a linksys cm100 modem with comcast isp, when connected hardwire from computer to modem I can connect to internet, but when i connected my Fry fr-300rtr with dir-615 E1 firmware it will not transfer...
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
Jan 31, 2011 | Linksys CM100 Cable Modem
Randomly the online light shuts off. No set time, no reason, all other electronics continue to work I TV on cable ,etc) Can shut down mu online functions w/o notice. Can the modem be shorting or...
First of all you can try by resetting your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
Aug 27, 2010 | Linksys CM100 Cable Modem
The install file on the CD that came with the Linksys CM100 cable modem does not work. Instead of installing, I INSTANTLY get the error message, ''installation failed''. I can open and read all the files...
You can ignore the CD. You don't need any kind of software to hook up a cable modem. Modems do not have anything to configure. Plug in your cable line, wire it to your router (or a computer) with an ethernet cable and you'll be good to go. If you have a static IP you'll just need to enter that info into the router. If you didn't specifically order a static IP from your ISP then you have a dynamic IP and don't need to worry about it.
Feb 04, 2010 | Linksys CM100 Cable Modem
Kinksys cm100 modem
try to do a powercyle ... unplugg power cord, 20 seconds then replug ....
Jul 25, 2008 | Linksys Wireless-G WRT54G Router
Linksys CM100 Cable Modem  Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
