Question about Brother MFC 420CN All-In-One InkJet Printer
Brother MFC-240_ printer Been unused for over a year. Replaced all the cartridges, loaded the driver successfully, prints up a storm but nothing is on the pages. Shows it is printing, cleaned the printhead numerous times but there is still nothing on the pages. Cannot scan, copy or print!!! Help...
  • 24 Answers
You say you cannot scan... have you tried using the scan software and scanning to a file? If this works but when you try to print or copy, the printer goes through the motions of printing and only a blank page feeds out then I think you are out of luck. I have worked on a large number of this model with this same problem and I have found that once ink dries inside the printhead (especially black as this is a pigment ink) then the only solution is to replace the printhead. This is an expert job and the cost of parts alone will be more than the cost of a new printer. If you have tried the purge sequence above a few times, check to see if the cartridges are still full. If they are then no ink has gone through the printhead and it will confirm the death of the printhead.
Posted on Apr 08, 2015
    Master:
  • 552 Answers
I think the heads r part of printer and not cartridge
if so they need to be removed and cleaned or replaced.
Posted on Oct 20, 2013
Testimonial: "How do you remove and clean them and are they replaceable and if so where do I get them. Been to the Brother live chat and they recommend cleaning the heads with power cycle cleaning yet again. Don't see how that can help. You can hear the ink squirting when you run the clean cycle and all ink well are showing full."
3 Suggested Answers
scrodamoon
  • 659 Answers
SOURCE: Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Posted on Aug 03, 2008
the kowalski
  • 86 Answers
SOURCE: Brother MFC 5840 won't print red. ink is full. printer head clean
If the regular cleaning does not work, you can try the power purge. Perform it by doing the following:
  • Press Menu, 2, 8, 6, 4 quickly (within about 1-2 seconds from the menu-press, all five buttons should been placed, in order).
  • The display and some buttons should start flashing, and it should say "Maintenance".
  • Press 7, 6.
  • It should say "CLEANING ALL", press right arrow key until you get "CLEANING MAGENTA" or similar.
  • Press 3, it should now change to POWER_P or P_PURGE. Press Mono/Black Start.
  • The display should say "Cleaning", when it's done, it will say Maintenance again.
  • Press 99 and you will leave Maintenance mode, you can now try and see if magenta works again.
If it doesn't work, you'd probably need chemicals to clean the ink tubes. But, this power purge should work.
Posted on Jun 05, 2009
Clean brothers mfc240 print head
You need to follow these options for cleaning your printer.
1. open your case and remove the cartridge from your printer and clean your cartridge area.
2. now you need to clean paper rolloer area.
3. once you will do that then you need to clean your printer tray and other area.
How To Clean The Cartridge For Brother MFC 240C Printer
for more information please watch this video.
Feb 21, 2015 | Brother MFC Office Equipment & Supplies
Brother mfc-495cw left idle for a long time. now won't print
Please notice that you will destroy the C/Y/M part of the print head because the ph needs the ink to prevent a dryout!!!
Simply stick some adhesive tape around the window in the middle between the ink-outlet and the valve. The flag inside signals the printer the ink level.Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 490cw Color Inkjet...
I installed a new black ink cartridge(lc61bk) on a brother mfc-495cw and now nothing is printing.
Check out if you've installed it correctly. Also check out other ink cartridges, are they empty? If yes you won't be able to print anything. However, if all ink cartridges are OK then try to reset the printer or reinstall the drivers. You can find help in MFC 495cw users manual
Feb 27, 2011 | Brother MFC 490cw Color Inkjet...
Model mfc-240 makes all the sounds as if printing but the paper comes out blank! nothing.
it shows that the ink has dried or finished, try to replace or refill the ink cartridge
do rate the solution if helped
Nov 26, 2010 | Brother MFC 240C All-In-One InkJet Printer
I haven't replaced the ink cartridges on brother MFC-240 printer, how do I replace it? I can't seem to find where its placed in the printer. Thanks
Here are instructions to replace your cartridges:
Brother MFC-240 Ink Replacement
BTW, here is the main support page for the printer with much more info:
MFC-240C Support
Add it to your favorites for future reference.
Thanks for using Fixya.
Mar 03, 2010 | Brother MFC 240C All-In-One InkJet Printer
What does cyan mean on a brother 240-c all in 1 printer it says replace cyan it wont do nothing
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
Mfc 240 c
Did you do a firmware update? If not go to brother homepage , download the update tool and do the update if it is avaiable.
Do you print with generic ink? If yes this prob is because of different color depth. Try to print with the original innobella ones or do some resettings within the printers properties when you print a pic from pc.
You may test the print out by printing directly from a picture card without pc.
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 420CN All-In-One InkJet Printer Logo
87 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
