Question about Gear Head Mouse
All buttons on mouse is bringing up right clicker menu. How do I fix it? It's not in the settings I've already checked.
    New Friend:
  • 57 Answers
what mouse is it - make and model ?
if it's Logitech - then it does come with a software, so look for that mouse setting - NOT computer mouse setting
if its there, try to uninstall the software from the control panel
hope this helps
thanks
Posted on Oct 19, 2013
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 94 Answers
It sounds like the mouse has failed (a hardware problem). It's easy to troubleshoot by testing with another mouse ... and ideally an identical one. If the next one also does not work properly suggest to reinstall the driver for the mouse.
My left clicker button has stopped working?
Yes, the switch part can fail. Repairing the motherboard can be labor intensive and costly. U might just want to consider using a usb mouse to work around the issue.
Mar 12, 2015 | Acer Aspire 5734z-4836 Laptop
Mouse clicker buttons not working
In Control Panel there is a mouse section, you may have the clicking disabled. if you don't and it still isn't functioning then you have a bad touchpad and it will need to be replaced.
You can also test using a USB mouse to find out if you have clicking disabled.
Feb 26, 2013 | Computers & Internet
Hi, my left clicker on my Sony Vaio stopped working. The right clicker works as well as the scroll pad but clicking on the scroll pad doesn't work as well. I have tried rebooting, installing the mouse...
More then likely the button has worn out.The first thing I would try to check to see if its the button or not ,just plug a mouse in to the laptop and see if that works with left click if it does it just may need a new button put in.If your handy you may even be able to do it yourself.If you have any other questions just let me know.
Jun 11, 2011 | Computers & Internet
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
Having trouble with the right clicker is the a easy way to fix it
You can open the mouse and clean it, should sort out the problem. The clicker also might have jumped out of place.
It would probably be cheaper and less hassle to purchase a new mouse.
Feb 07, 2010 | Logitech 9312210403 Mouse
My right click menu pop's up when ever i try to click on my laptop anywhere, i have a DELL inspiron 1520.
is your pointer set to be opposite... go into control panel and mouse options, and see if you accidentally switched your mouse clicker buttons.... try clicking with the right click, does it still open your 'right-click' menu? does it work normal on an external mouse?
maybe its just a setting issue,... if not then prolly need a new mouse pad...
Sep 25, 2009 | Dell F3534 Touchpad
Thinkpad T61 mouse left click not working since yesterday. However the right clck and other keys are working
ok go to control panel and mouse settings and make sure that for the left button its checked to bring up menu or double click or whatever you like
Jul 26, 2009 | IBM Thinkpad T61 Motherboard
Context menu continually pops up - mostly when left mouse button is clicked sometimes when keyboard is used. Context menu key doesn't work.
I think the mouse setting is set to left handed and the right clicker is the main clicker and the left is the context menu key. Knowing this, you should follow these steps.
1. Go to "Control Panel"
2. Click "Printers and Other Hardware"
3. Click "Mouse"
4. Go to the "Buttons" tab and switch the setting to right handed
Jan 31, 2009 | Compaq Presario Notebook
Left clicker doesn't work on my hp optical mouse
Sorry to say it's most likely a failed switch on the mouse. You will have to replace it. Try a hard-wired mouse first if you can to confirm.
Dec 09, 2008 | HP Wireless Optical Mouse
When I'm typing, the cursor moves
To resolve this issue please follow the steps below:-
1) Locate the picture icon called "Synaptics Touchpad" or "Pointing Device" that is located next to the digital time (usually in the bottom right hand side of the screen).
2) Click on the icon with the right-hand mouse clicker and select the option: MOUSE PROPERTIES in the small sub-menu that pops up.
3) You should now see a new window dominating the screen with several options and tabs along the top. Select the "Tapping" tab listed there with the left-hand mouse clicker.
4) When Tapping Selected the menu window will change presenting some new options. There should be an option near the bottom of the menu called "Tap off when typing" Click the box next to this menu option, success will bring up a little tick in the box clicked on.
5) To the right of the "Tap off when typing" option there should be a new sliding controller available with two options on either end (Short ---- Long) and a triangular shaped slider button in the middle of the two. The triangular shaped button needs to be moved to approximately three-quarters to the right (towards "long").
6) Once above step has been completed left click select the "Apply" button on the bottom right hand side of the menu, and then click "Ok" to confirm changes.
Hope this solves your problem :0)
Dec 27, 2007 | Toshiba Satellite P105-S9722 Notebook
Gear Head  Mouse Logo
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
