Question about Philips 50PFP5332D 50 in. Plasma Television
Philips 50PFP5332D/37 Plasma TV... I have a black vertical line approx 3" wide, to the left center of the screen. Everything else works great on it. What is causing this and how can I fix it? It's always there. The TV is approx 6 years old and no warranty. thnx
  • 2,113 Answers
After doing some research online for black lines on a plasma tv i see that the cause on some was a loose connector inside the tv
Posted on Oct 19, 2013
Testimonial: "Thanks for the fast reply... I'll check all the connection again. Just a note, some of my research I found is that some people just had a bad IC on their Y buffer board(s) and either figured out which one and replaced it or they just replaced the one or both Y buffer boards. I'm just trying to get hard facts IF it is the Y board(s). lol... hate to spend money on boards and that wouldn't be the problem."
4 Suggested Answers
jdbouncer
  • 72 Answers
SOURCE: philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Posted on Apr 29, 2008
IrishDruid
  • 2712 Answers
SOURCE: 5 different colored vertical lines on black and white picture.
Hello wisportsfan2,
Try the following first:
If you are using a direct cable connection from the wall outlet;
  1. Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
  2. If the connection is good, perform the auto program and ensure that the Installation mode (Antenna or Cable) is selected correctly.
If you are using a coaxial connection from the Cable or Satellite box to the TV;
  1. Set the TV to the channel specified by the service provider.
  2. Change the channels at the Cable or Satellite box to view the program.
If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
  1. You do not need to perform auto program to search for the channels.
  2. Press the 'SOURCE' button on the remote control repeatedly to select the correct input source.
If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
  1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
  2. Press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
  3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
  4. Turn on your source.
If you are sure you have selected the correct input or channel but still have no picture and sound;
  1. Try resetting the TV by unplugging it from the power outlet for 30 seconds.
  2. Press the 'SOURCE' button to select the correct input source.
You can try the "Whack" method first though..Just smack or whack the set with your hand or fist around the cabinet to see if that will either aggravate or restore the picture. If so, it means there is a loose connection or cold solder joint of some kind, which you may be able to repair yourself if you have the soldering skills.
If it still does not work, it looks like there is a problem with the vertical blanking due to faulty ribbon connectors, although there are several things that can cause it.
But in my honest opinion, it is best to have an expert technician come in and do some tests on it in order to diagnose the root cause of the issue. It is not easy to fix this yourself, if you have no experience, as there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
If you wish to contact Philips customer support to arrange for a service, please call 1-888-744-5477 Monday - Saturday 7:00 am - 11:00 pm EST Sunday 8:00 am - 11:00 pm EST Excluding major holidays
When you contact Philips please have available:
  • The exact model number
  • Your date of purchasing
  • The serial number of your product
Send an e-mail
Hope that helps! If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides helpful information that helps solve the problem.
  • "Thanks for Trying" - The solution provides some help but does not solve the problem.
  • "Inappropriate" - The solution has nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 04, 2008
ricky_PT
SOURCE: I have a 50" plasma Philips tv 50pfp5332d/37 it
feadwf e wrwer we wr rw we r
Posted on Aug 30, 2011
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Half of my screen plasma TV 50" is black. What I have to do to fix it? plhilips plasma tv model 50PF7321D/37
Your Television problem on vertical section.
Solve: If you repair itself replace vertical IC or thoroughly resolder dry any components.
Jan 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
Only get black & white, double images
bad power circuit may cause such problems.
may be power ic or bad capacitors.....
Aug 18, 2017 | Philips 50PFP5332D 50 in. Plasma...
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
has only one main board
has many sub bords supporting tat main board
Mar 08, 2009 | Philips 50PFP5332D 50 in. Plasma...
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Philips plasma tv vertical black stripe
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Help
On Philips LCD and Plasma TV's you can center the picture left and right and also vertically. Use the round joystick in the center of the remote to see of you can shift the image to the left.
Dec 01, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 50PFP5332D 50 in. Plasma Television Logo
193 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
