My staples spl-txc122a just stopped working it is not jammed and doesn't even go on any suggestions?
SOURCE: Staples SPL-1506X
Well, despite the manufacters warning label I choose to take the shredder apart and found that one of the plastic gears was broken. Hence the motor runs, but the blades do not turn. The thing I didn't understand, the there are metal gears and plasic gears...I can only imagine that the plastic gears at one point or another are going to give. I would suggest not to void the manufacters warrenty, take the shredder back, and get one that is built a little stronger. Hope that helps.
Posted on Aug 12, 2008
SOURCE: staples shredder spl 727mm - quit working all of sudden - jammed?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}First, don’t destroy anything on the top of the machine.Eight screws. Two are accessed through the rubber foot pads. Six are accessedfrom the basket compartment. You will need a VERY LONG AND SKINNY Phillipsscrewdriver with a foot-long blade and a very narrow diameter to fit down theaccess holes. I cut my case in two to get at the six screws through the basketcompartment (very messy). It would probably be easier to drill holes throughthe bottom of the case for screw access. You could then use tape to cover the holes.
Our shredder quit running while in use. Staples said itwould probably need a new circuit board. Once I got inside I found a 5 amp fusesoldered to the circuit board. Yes, it was blown. I jumped it and the machineworked. I unsoldered the fuse and soldered in two wires that I ran through ahole I drilled in the top of the machine. I took a 5 amp automotive fuse(bayonet style) and drilled a small hole through each bayonet. I then threadedthe two wires through the two holes on the fuse and wrapped them around,instead of soldering, for easy future replacement. Then I wrapped the fuse withelectric tape for safety and taped the fuse flat to the top of the machine.Voila! A flawed Chinese product is made usable! Dan Phelps delps@charter.net
Posted on Mar 13, 2009
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
SOURCE: staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Posted on Jan 08, 2010
SOURCE: Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Posted on Jun 23, 2010
I'm looking for a manual for an spl tmc162a staples shredder
The bin has not been inserted sufficiently to close the interlock switch.
Feb 04, 2018 | Staples Office Equipment & Supplies
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
Lockout key replacement for paper shredder model# SPL-TXC122A
I am not sure what you mean by a LOCK OUT KEY but perhaps this link to the manufactures site might help.
www.fellowes.com/us/en/support/Pages/faqs.aspx Fellowes Support FAQs
Jul 13, 2014 | Staples SPL826X (CrossCut) Shredder
Parts manual for SPL-TXC122A
I need a plastic gear for the Staples SPL-TXC122A Does anyone have one?
Apr 06, 2013 | Staples TXC122ACC Cross-Cut Shredder; 12...
Spl-txc122a
The motor runs reverse even when in Auto mode, how do I fix it, and why did it happen
Mar 27, 2013 | Staples SPL1506X (CrossCut) Shredder
Staples SPL-770M shredder with overheat light even when cool
Sep 10, 2009 | Office Equipment & Supplies
592 people viewed this question
k24674
jasbo
jasbo
