Question about Electrolux EL8505A Bagless Upright Vacuum
Electrolux versatility el8505a lights up when plugged in but wont turn on
  • mel june
    mel june Oct 22, 2013
    the writing on the bottom piece where it says "electrolux versatility" it looks clear but when you plug the vacuum in it letters turn blue like the vacuum is on but when you hit any of the switches nothing happens. it doesnt turn on or anything. i looken into buying a new switch but they are not easy to find and usually used and not returnable
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 179 Answers
What lights up? does it work when connected to the blower end? Does the power nozzle work?
Posted on Oct 21, 2013
2 Suggested Answers
SOURCE: I have Electrolux Versatility and
Unplug the machine..now if you remove the attachment hose at the body of the vac and feel inside (to the right about an inch) their is a "suction cover" that rotates when the wand is removed (aka using atachments). The cover in your machine is NOT rotating correctly, so it does not get full suction. If you do get some suction from the hose then their is at least a 'small opening' because it has partially rotated. I was able to fix this problem by taking a large screwdriver (1.5 feet long, thick as a pen), inserting it into the small opening (on the suction cover, inside to the right at the top) and forcing the cover down all the way by lifting the screw driver up against the top of the body opening. Seems to have corrected the problem, but may reoccur. If you have NO suction at all then it has failed to rotate whatsoever, and Im not sure how to correct it.
picture of the suction cover part:
http://evacuumstore.com/p-3604-electrolux-versatility-el8502ab-cover-suction.aspx
Nice of that sales lady to provide zero help...
-Steve
Posted on Sep 18, 2012
Where is the reset on electrolux EL8505?
it may be the rocker arm located under the the switch.They are plastic and break,best bet is to take it to a repair shop Not too expensive of a fix
Sep 01, 2014 | Electrolux EL8505A Bagless Upright Vacuum
How to fix expelling dirt from electrolux versatility?
sounds like the vacuum is blocked.Turn vac on its back and check the area where the dirt goes in,there is probably something stuck in there....
Jun 23, 2014 | Electrolux EL8502 Versatility Bagless...
Problem with Electrolux Vacuum Cleaner, MDL EL8501A. Brush Roller will not turn
try pushing the reset button..its a little red usually located on the right side of the nozzle cover..
May 27, 2014 | Electrolux Versatility Bagless Upright...
EL8505 brush will spin at only certain handle positions. The brush is unhindered and the belt is in position and in good order. The vacuum feels like it is sufficient. When the brush is not spinning the...
Many vacuums have a switch positioned somewhere by the pivot point that is pressed when the catch is released and the handle taken out of the 90 degree storage position. I haven't worked on an EL8505 but I have fixed a couple other brand / model vacuums that were behaving the same way you describe in your problem. In most cases it is either a perfectly good switch that had moved out of position because the framing it is supposed to sit in is broke or worn down or a bad switch that only works when the plunger was in just the right spot.
The link is a parts blowup of your vacuum and I think A-26 is the part you need. It appears to have both the bracket and the switch in one part. Make sure where it mounts doesn't have any damage preventing it from staying in the right place and alignment.
Electrolux EL8505A Parts List and Diagram eReplacementParts com
Mar 23, 2014 | Electrolux EL8505A Bagless Upright Vacuum
The belt is fine and tight but when you turn on vacuum the motor doesn't spin at all to turn the brushes
You will have to see if there is power getting to the motor and if so maybe it is burnt out. Could even be a bad switch.Make sure your receptacle is working where you plug it in. Also check your wiring as well as the plug. sometimes a wire could be broke.
Feb 27, 2014 | Electrolux EL8502 Versatility Bagless...
I cannot find a replacement belt for my Electrolux versatility HEPA bagless upright vacuum cleaner. Model# EL8505B
You can try to get a belt directly from Electrolux or maybe a local vacuum cleaner repair shop
Aug 14, 2013 | Electrolux Vacuums
I have electrolux 4000 upright,when turned on roller works but theres no suction
maybe your hoses are plugged with something. would happen to mine and i would find all kind of stuff in there. give that a try
Oct 14, 2012 | Electrolux EL8502 Versatility Bagless...
I have Electrolux Versatility and have little suction power in the hose part,
-Steve
May 05, 2011 | Electrolux EL8502 Versatility Bagless...
Electrolux EL8505 does not have suction. Hoses have been checked. No warning lights on. Help
I had the same problem I found a clog in the hose between the beater brush and the canister. I used compressed air to unclog.
Apr 27, 2011 | Electrolux EL8502 Versatility Bagless...
Electrolux EL8505A Bagless Upright Vacuum Logo
60 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
