Question about Saeco Coffee Makers & Espresso Machines
Saeco incanto classic s-class auto espresso machine
While cleaning the machine inside a small 3 sided part fell out. Cannot see where it should go and my helper does not know where it came from. The part is about as big as half a gem clip. Can you please help. The coffee machine is working without it. regards Emanuela
  • 515 Answers
Do you have a picture on this part?
Posted on Aug 12, 2008
Apr 24, 2014 | Saeco Incanto Classic Espresso Machine
How to drain coffee machine saeco s-class incanto classic
Subject: How to drain boiler of Saeco Incanto Deluxe
I got an answer from Saeco Customer Service as follows:
Good Afternoon,
All you need to do is have the machine turned on and up to temperature. Make sure that you have a full tank of water as well. Make sure the machine is set for hot water, then turn the knob on the side of the machine to start water flow. Once the water is flowing out, remove the water tank and, leaving the knob turned open so that the water that's in the system drains out. Once water stops coming out, close the knob and shut the machine off.
The water is now drained from the system.
Thank You,
Customer Service
Saeco USA
Feb 23, 2010 | Saeco Incanto Classic Espresso Machine
How do you get the float out from the water tank on a Incanto S Class Saeco Coffee machne
On most of the machines there is a small plastic square plug above the float, if you remove that the float will come out.
Sep 09, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Housing Jammed
Here is the manual. Try page 11. Did you take the drip tray out first? You move the "push" part to the right and while doing so use your other hand to pull the whole unit out. The "push" part is a small movement.
Jan 17, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Sirius S Class
Take off the top of the machine, look at the printed circuit card and see if you can see anything that is broken.
Look at the fuse in the machine to see if they need to be reset.
Best regards
Oct 17, 2008 | Saeco Incanto Classic Espresso Machine
Coffee machine
I had the same problem. It had to go back to the service department and a replacement part was needed.
May 17, 2007 | Saeco Incanto Classic Espresso Machine
Open Questions:
Defect Saeco Odea Giro. Red exclamation flashing fast. Mashine is function only in service mode. A defect in Saeco Odea Giro. TYP 0310R ser. number. 9007SA40523803 Please help for repairing the machine. I bought the automatic coffee machine second hand. After unpacking, I discovered that someone was intruding into it cracked plastics and handles. By common check, I discovered the 1st fault - a broken piston catalog number 11003468. This is quite a common fault with these machines. 2nd defect leakage of the valve. Even one O ring was missing. I replaced all O-rings with new ones. Then I went over to check the individual sensors: Level sensor in the tank - OK Sensor closed coffee bean hopper - OK Sensor of closed door on the brewing unit side. - OK Sensor on the waste container - okay When I wanted to try switching on a microswitch that detects the presence of the brewing unit in the hole, I did not find contact. So I removed the wall behind the brewing unit and found that there were two microswitches near the toothed wheel. I checked their functionality. Both well. I assumed that one of them was not at his destination. The one with the green connector I supposed to indicate that the brewing unit is in place. I moved him to the top. I checked the state of the electric motor and lubricated the gear. I returned the wall back. Next, I ran the diagnostic mode and checked other components: a Boiler - Heats up b The pump - presses correctly and the green diode flashes during its operation and shows the activity of the flowmeter c solenoid valve - switches correctly d the grinder grinds and during its operation the green diode flashes and reveals the activity of the speed sensor in the mill e the brewing unit is moved to the top position and to the basic position without any problems Other things I've done: The whole coffee maker is cleaned, deep decontamination is performed using the diagnostic mode. Check the flow meter clean without oxidation. Check the tightness of all hoses. Both boiler thermostats are checked. Removed and thoroughly cleaned the mill. Despite this, the machine behaves as follows: Turn on the machine and fne the mill shaft. The red exclamation mark flashes very quickly. The green light of the boiler heating is not lit or flashing. However, the boiler is heating up properly. When I eject the tank water flow, the red exclamator lights up permanently. After the tank returns, the red exclamation mark will flash rapidly again and the green indicator the boiler is heated will light up properly. When switched on, the Indycatter does not light the cup. Only a drop of water drops and coffee beans lit up. Can not prepare coffee, can not refuel hot water. All this can only be done in diagnostic mode. In the diagnostic mode, I also de-aerated the machine. Both the nozzle and the coffee outlet through the brewing unit. Self-cleaning will not start. I do not know anymore, maybe there is a bug in the electronic panel. Will anyone advise me? Thank you.
Mar 09, 2018 | Saeco Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
149 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
