The thing that you pull to get the machine working broke. I dont know what it is called :(
SOURCE: craftsman 4 hp 2150 psi pressure washer wont start
Go to www.karcher.com ,click on your region and then click international. Enter the model of the machine or the type number . That is is the first 8 digits of the number under the barcode. This will take you to the parts listing for your machine.
SOURCE: I hAVE A 2600 PSI HUSKY PRESSURE WASHER, AND I
remove the pressure hose and turn your water supply on and water should flow thru the pump on out where the pressure hose is. If not you have a blockage in the pump.
SOURCE: Owner's manual for Husky #HU80432 pressure washer
If you can't find it under Tech Support, Manuals & Guides on this site you could go to: http://huskypowerwasher.com/manuals_specs.php
You can also call Husky at: 1-888-550-1606 from 8:00 AM to 4:30 PM Central time.
I hope this helps.
Testimonial: "thanks for the info. the # that I was referred to for manuals is - 866-340-3912."
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
SOURCE: pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
