Question about Broksonic SC975 19 in. TV/DVD Combo
How do I change the language to English on the Broksonic TV?
My goodmans tv LD3270D has changed language when I was trying to change the audio for my tv, it is now in german, and my sky volume is now in german too, I need to get it back to english.
language preferences are usually very early in the set up screens, if you can't toggle it back to English using google translate to help, look for a reset to defaults, default language is usually English, but then you will have to set all your other preferences again: https://translate.google.co.uk/
Jan 01, 2016 | Goodmans Televison & Video
I have a panasonic viera th20lx70 tv and i want to change its language from Japanese to English please brief me
Check your menus for a language area and if there make the appropriate correction.
Nov 21, 2015 | Panasonic Cameras
How can i change my tv language back to english?
Hi dear,
Kindly mention model number of your tv.I will give you the solution.
Aug 19, 2014 | Konka Televison & Video
Change language from Spanish to English Vizio 323SV
You may have to go back to the setup procedure and search for a language option to select English.
Dec 19, 2013 | Vizio VO320E LCD TV
MY TV MENU HAS CHANGED TO A FOREIGN LANGUAGE
HI there
Start the set-up again work through to languag. There you can change back to English.
Good luck
Kolbrun
Feb 26, 2012 | Sharp LC Televison & Video
How do I change my tv from spanish to english
go to the main menu and select on the screen untill you reach to the language selection then select english as you purpose
Sep 21, 2011 | Broksonic Televison & Video
Samsung led tv how to set up to english language??
solution
If your TV program available to language .
you must be select or change your choice full language or English.
any whey ,you first in your TV language program Menu and select language setting to select your language.
Send report :babul_jpi90@yahoo.com
Jul 27, 2011 | Televison & Video
Language selection
you must go into the menue and set up wich is gona be hard because you are in another language but good thing is setup usualy the first menue selection once the main menue comes up then you gota figure out witch one says english snd hit enter
May 06, 2010 | Broksonic CTVG-5463GVC 19" TV
I can not set up the tv as the language is not in english and i can not work out how to change it to english
. i can not set up the tv as the language is not in english and i can not work out how to change it to english
May 03, 2008 | Hitachi 51F510 51" Rear Projection...
Broksonic SC975 19 in. TV/DVD Combo Logo
29 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
