Question about Linksys SRW2024 24-Port Gigabit Ethernet Switch (SRW2024KIT)
Power supply cisco - Linksys SRW2024 24-Port Gigabit Ethernet Switch (SRW2024KIT)
I was wondering if the PWR-2911-POE and PWR-2911-AC can be installed in same 2911 router? Thanks.
No, both of them are power supplies. PWR-2911-AC is the standard power supply but the PWR-2911-POE is a bigger power supply to power up EHWIC or single/double-width line cards. Moreover, there is no physical way to put two same/different power supplies into a 2900 router. But 3800/3900 routers can support dual power supplies. Cisco 2900 Router Price Buy Cisco ISR 2900 Series Routers 3Anetwork com
Apr 03, 2015 | Cisco Computers & Internet
Cisco WS-C2960-24-S switch port not working
Can you tell more details, there's various possibilities to cause the switch not work...
You can check your switch from these way:
1 check your cenect cord
2 check the power supply
3 check your network environment
For the Cisco switches, if you have any problems you can feel free to send email to our technicist:
support@3anetwork.com
Cisco Price Cisco Switch Price Cisco Router Price Buy Cisco Switches...
Dec 14, 2012 | Cisco Catalyst 2960 24 10/100 (8 PoE)...
Not working cisco 7962
For starters, have you obtained a Cisco Phone power supply for your 7962G? These phones require either a local 48V AC Adapter, or Power Over Ethernet, in order to power up.
Mar 04, 2011 | Cisco 7942G IP Phone
Hello, my cisco ip phone does not start
Confirm if the Phone has power supply. and If it's connected to a POE switch confirm that it connects to the Switch port on the phone.
Oct 14, 2009 | Cisco Computers & Internet
7945g can't use power supply of 7940
You'll need to buy a another power supply unless you have power over Ethernet. The power supply for 7940G/7960G is CP-PWR-CUBE and for 7941G/7945G you'll need a CP-PWR-CUBE-3. Yes, I know, I just got one of those and it's a pain to configure it, but I got it working... ;-)
P.S. If you haven't notice, you will be dealing with a whole different thing, the configuration/settings will ALL (except for the dialplan file) different from the 7940G... Good Luck ;-)
Aug 02, 2009 | Cisco 7945G IP Phone
CISCO 2600 Router Troubleshooting
This is the indicator configuration for the 2600, if the lights are yellow there is a problem.
The following indicator LEDs provide power, activity, and status information:
POWER (green)—Lit when power is on
RPS (green)
Off—No redundant power supply (RPS) is present
Blinking—System is booted, RPS is present, RPS failure
Continuous on—System is booted, RPS is present, no RPS failure
ACTIVITY (green)
Slow, steady blinking—System is booting
Blinks during system activity, such as interrupts and packet transfers
I suggest going to Cisco.com for full documentation on this product.
Feb 19, 2009 | Cisco RPS 22/18 (cab-rps-2218)
No power to cisco 5505 ASA
http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
From the US, you can call: 1.800.553.2447
From there, Cisco will be able to tell you what your warranty status is by the device's serial number, and can also provide you with a quote if your warranty has expired.
Oct 08, 2008 | Cisco ASA 5500 Firewall
Cisco 2960 power supply
The Cisco 2960 has a life time warranty. Contact the seller and they should be able to get the switch exchanged at no cost.
Jul 31, 2008 | Cisco Rf Catalyst 2960 24-PORT 10/10
No power
Here are a couple of ideas...
Check out ebay item #140197449460
- or-
http://www.cablesandkits.com/cisco-power-supplies-c-63.html
Jan 18, 2008 | Cisco Catalyst 3560-24PS Switch
Cisco 2801 router's power supply
Suggest you go to Cisco for two reasons....A) it may not be an off the shelf item you can cross source and they can be different (even within the same external model number)...be careful or take a look at the supply itself (open sesame). Hope this helps....Tango
Jan 14, 2008 | Cisco 2801 AC PWR SUPP (PWR2801AC) Power...
Linksys SRW2024 24-Port Gigabit Ethernet Switch (SRW2024KIT) Logo
21 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
