2002 Land Rover Freelander where is the engine cooling fan switch locate
    Problem Solver:
  • 7 Answers
Its controlled by the engine management computer directly, I believe.There are only sensors telling the computer the temperature. If its too cold, it operates the preheater system. If its too hot, the computer controls the fan till it is cool enough for the computer to switch it off. Its a modern car. There's no switch, and no timer mechanism. The fan can even come on when you already parked and got out of the car.
Posted on Dec 17, 2013
How to reset timing marks after replacing a broken timing belt?
Land Rover Freelander 2002-2005 KV6 Timming belt and ...
? 4:31
https://www.youtube.com/watch?v=sz_oe9tIFH4
Jul 3, 2011 - Uploaded by Jaime Depaula
Land Rover Freelander 2002-2005 KV6 Timming belt andreplacing valves - Video 2 ... shops in North Eastern USA for bent valves and timing belt change? .... Land Rover 200tdiTiming Belt -From Broken Belt to Retiming the ...
ROVER K Series Cambelt Change Video - YouTube
? 10:52
https://www.youtube.com/watch?v=1Qn8ljQKZxA
May 4, 2012 - Uploaded by metalworker007
How to change a rover K series cam belt .. by Technozen of ...soy espa?ol porfavor quiero saber timing marks de MG ROVER 25 petrol 1795cc engen .... Hi, Have a Land Rover Freelander1999 petrol serie K, that dont start, ...
Freelander 1.8i timing belt - Land Rover Technical Archive - LR4x4 ...
forums.lr4x4.com > ... > Tech Archive > Land Rover Technical Archive
Nov 20, 2006 - 1 post - ‎1 author
The following is instructions for replacing the timing (or camshaft) belt on the 1.8i petrol engine, as fitted to a Freelander. This is the K-series ... With the timing set, thecam sprocket marks should look like this. Posted Image
How to Replace timing belt on Land Rover Freelander 2.5 ...
Dec 10, 2015 | 2002 Land Rover Freelander
I have a 2002 Land Rover Freelander that is stuck in Park. The stop light switch has been replaced with an autozone part, but it still does not work. The break lights are also not working.
This might help you. Otherwise, just find a mechanic you trust and have him or her check the brake light bulbs. It could also be fuse problems. Check the diagram for your lights or check your manual. http://forums.edmunds.com/discussion/5166/land-rover/freelander/freelander-transmission-problems
For your fuse box diagram:
http://carwiringdiagram.net/2002-land-rover-freelander-fuse-box-diagram/
May 31, 2015 | 2002 Land Rover Freelander
My 2002 freeLander cooling fan is not working at all what is the problem
check to see if the motor is working by jumping it straight to the battery. If it does then its the temperature switch by the thermostat. If that isnt the problem, it can only be the relay. Check the wires for breaks
Jan 10, 2011 | 2002 Land Rover Freelander
2003 kand rover free lander cooling fan does not come on,causing
Check your fuse and fan relays. You will likely have to consult the owners manual to find location. The relay will probably be under the hood, the lid to the box is usually labeled as to what goes where as well.
Aug 25, 2009 | 2002 Land Rover Freelander
2002 landrover freelander cooling fan assembly
The fan module is the big silver box with fins on it, right next to the fans. Just follow the fan cables and you will find it. Don't jumper the fans without unplugging or you may destroy the power transistors in the fan unit. Check the temperature sensor for the fan control unit - near the front of the engine - it should have some resistance - not be short circuit or open circuit, it is a sensor, not a switch. If short or open, that is likely to be the problem, otherwise, ensure that the control units have electrical supply, otherwise, it is very likely to be the control unit.
Jul 16, 2009 | 2002 Land Rover Freelander
Cooling fans stay running even if engine cold
cooliant sensor is bad ,you have two,one for cooliant temp and one for cooling fan both are in therostate housing or in some of the cooliant ports,
Jun 15, 2009 | 2002 Land Rover Freelander
2002 Land Rover Freelander radiator and air fan not working
there is a module mounted on the fan shroud that is a common problem. but as always, check fuses, connectors and grounds!
Jun 10, 2009 | 2002 Land Rover Freelander
Land Rover Freelander heater/fan switch not working
u need a Freelander Blower Fan Speed Repair Kit
go on e-bay Item number: 160320517862
Mar 09, 2009 | 2002 Land Rover Freelander
Coolant fan
check to be sure the lower hose is hot and you have good heat when this happens, if not your thermostat is stuck change this. if its hot there is a fan themo switch located on the radiator that may be suspect please advise good luck -jeff be sure to rate this !
Aug 13, 2008 | 2002 Land Rover Freelander
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
