Question about HP Color LaserJet 2600n Printer
I got an inexpensive used HP Color Laserjet 2600n that needs a new ETB belt as it's putting vertical stripes on the pages. Do I have to purchase the whole assembly or can I get just the belt. Also, where's the best place to purchase? Thanks!
  • Wayne Shaddock
    Wayne Shaddock Oct 19, 2013
    These are the stripes I was referring to...please correct me if I'm wrong about the cause.
  • 40 Answers
You have to buy the complete transfer belt assembly. I used to buy mine from express terminals but haven't used them for a few years, I would buy oem a lot cheaper and work just as good.
Posted on Oct 19, 2013
Testimonial: "Hi Tim...I appreciate your attempt to help, but I would offer 2 suggestions: 1. Include a link to the supplier or a better way to identify them. A search turned up nothing that seemed to match and www.expressterminals.com didn't work out either. 2. I think you meant 'compatible' rather than 'OEM' which stands for 'Original Equipment Manufacturer' which would generally be the more expensive products."
  • 1 more comment
  • Wayne Shaddock
    Wayne Shaddock Oct 21, 2013
    So I noticed that the cyan toner cartridge has stripes on the OPC drum exactly corresponding to the (slightly greenish) stripes I'm getting on the print jobs. Although the transfer belt looks a little beat up, I'm starting to surmise that the belt isn't the reason for the stripes. Can anyone speak to these thoughts?
  • TimmyQMS Oct 21, 2013
    By looking at the pic, it looks like you need to replace the cyan drum as you say they line up with the marks on the drum. i find if the belt is faulty its normally the cleaning blade on the assembly and would leave all color streaking not one color. with regards to last comment i have not used express terminal in years so not sure if still in business and yes sorry i did mean compatible i hope this has helped.
  • Wayne Shaddock
    Thanks, Tim. As a follow-up to my testimonial I'd just like to say: Great job! A very helpful FixYa community member. Mark this as a solution Mr. Moderator. ;-)
4 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: What is the best way to clean the transfer roller
dont clean, unless glued up, but they dont like it, can spot remove stuff with metho, but they last about 60000 pages cause little problems unless torn, Some models just unclick by buttons either side near hinge others are fixed and normally thrown if damaged or charged heaps.... Most faults are alignment issue, faulty remanufacture cartridges or damaged fuser (hot bit) roller causing creasing..
Posted on Nov 07, 2009
Testimonial: "Good job, Thank you."
  • 3 Answers
SOURCE: HP Color Laserjet 2600n Color Alignment
I own a HP 2600n and I had the same problem the way I fixed it was hold both arrow buttons in the turned off the power for 10 seconds while holding the buttons in then turned it back on then released after 3seconds the reset my defaults this cured my problems
Posted on Nov 12, 2009
SOURCE: hp color laserjet 2600n displays error 55.1 turn off then on
hello friend i have a printer HPColor Laserjet 2600n it displays Erroe 55.1 Turn OFF/ON. How do i over come this problem?thx
Posted on Jun 15, 2010
Can you clean the ETB on the hp 2600n laser printer
yes you can clean it..you can use 40% solution alcohol
May 27, 2012 | HP Color LaserJet 2600n Printer
Error 59.9 after cleaning a HP 2600n
59 errors have something to do with the ETB(electronics transfer belt).
Try reseating the belt, see if that doesn't fix your problem.
When was the last time that the ETB was replaced?
Oct 17, 2011 | HP Color LaserJet 2600n Printer
Cant get the hinge installed so that the toners open and close as you open and close the door.... HELP!!
I got a feeling that the ETB isn't seated correctly.
The ETB is that big mylar belt that lowers with the front door.
Pull the ETB out and check that both black plastic sockets are in the down position.
Now reinsert the ETB making sure that it sits in those black sockets, one on either side.
Mar 15, 2011 | HP Color LaserJet 2600n Printer
Is there something I can clean on my HP Laserjet 2600n. I've done the recalibration and things that are built into the menu system. The colors appear faded, especially red. There's an echo-type of...
Using the REPORTS MENU print the "color supplies status". Make sure everything is good.
Select SYSTEM SETUP. Select PRINT QUALITY. Select CALIBRATE COLOR. Select CALIBRATE NOW.
Check the Transfer Belt(ETB) which is inside the front door. Make sure that it is free of your "racing stripes".
You can use HP TOOLBOX to troubleshoot.
You are using HP cartridges???
Dec 12, 2010 | HP Color LaserJet 2600n Printer
I am experiencing some "shadowing" when I print a document
The problem most like resides in the ETB or electronic transfer belt....The image is not being removed from the belt to the paper causing shadowing effect...you need to replace the ETB. Try www.getthatpart.com they have great units at great prices and have someone on the phone you can talk to. If you feel its not the ETB and you don't see any toner left on the belt call these guys up and they can help you futher
Oct 25, 2010 | HP Color LaserJet 2600n Printer
We have a HP Color Laserjet 2600N and I am getting lighter impressions down the left side of printing... do you know what causes this, and what I can do to resolve it? I am unable to find an answer on HP's...
I would recommend before ordering the transfer kit to clean the Transfer Belt
To clean the ETB, use the following procedure:
- Enter the Secondary service menu.
- Scroll through the menu and select CLEAN ETB.
- Press the(SELECT) button to start the cleaning mode
here is a link to view the manual on-line
click here
Oct 19, 2010 | HP Color LaserJet 2600n Printer
When printing with the hp color laserjet 2600n printer, continue to get a double gray images for words and pictures. I have follow all online hp directions to fix this problem with no success.
1. Make sure that the control-panel display reads Ready.
2. Press and hold the LEFT arrow (<).
3. Press the CANCEL (X) button and release both.
4. Press the CHECK button, 2ndary Service will be displayed. Press CHECK again to access.
5. Use the < or > button to navigate the secondary service menu.
6. To remove the secondary service menu from the menu tree, power-cycle the product.
- access 2ndary service menu
- run "clean ETB" to cleanup the belt
- set paper to heavy or cardstock, print 10 blank pages to celan up the fuser
- try printing something
- if issue perists, send something to be printed and before it comes out, open up the front cover to stop the printing process, take out the page from the cartdridge area
- if the issue is noticeable on the top of the page but not on the bottom, the problem is with the fusing assembly
- if the issue is noticeable on the top of the page and on the bottom, the problem is with the transfer belt or one of the toner cartdridges
Jul 24, 2010 | HP Color LaserJet 2600n Printer
How to exchange the ETB unit (belt) on a HP Colorlaserjet 2600n?
To replace the ETB Belt.. follow this step..but it would be easier if I can show u the diagram.. I will figure a way to upload. but let see if u understand here...
ETB removal and replacement
Use the following procedure to remove the ETB (RM1–1881–000CN).
1. Remove or slightly pull out Tray 2 (RM1–1916–000CN).
2. Remove three (3) screws, two (2) from the right cover assembly and one (1) from the left cover
assembly.
3. Open the front door.
4. Remove the right cover (RM1–1858–000CN), carefully twisting the front edges of the side covers
outward to remove.
NOTE : To make the removal of the right cover assembly easier, release the tab on the
inside of the cover.
5. Remove the left cover.
6. Squeeze the white link lever on the left side.
7. Remove the screw on the right white plastic catch, and then remove the plastic catch.
8. Close the ETB.
9. Remove the small black cable cover (RC1–5147–000CN) on the left side of the printer by
carefully snapping it out of place.
10. Remove one (1) grounding screw from the ETB harness.
11. Pull out the white wire holder by pushing it up.
12. Pull out the ETB connector.
13. Remove one (1) screw from each hinge cam on both sides.
14. Using needle-nose pliers, remove the hinge left cam (RC1–4249–000CN) and the right hinge
cam (RC1–5311–000CN).
15. Remove the ETB.
Use the following procedure to replace the ETB.
1. Align each foot of the ETB with the respective holes, securing the right side first, and then the left
side.
2. Complete replacement by following steps 1 through 14 above in reverse order.
NOTE : When replacing the right cover, align the tabs on the upper edge of the right cover
and lower edge of the face-down cover with their respective slots.
May 23, 2010 | HP Color LaserJet 2600n Printer
Color ink on transfer belt
I posted the problem on 4/6/09 about my HP Laserjet 2600n with the black line from top to bottom on all pages. The issues ended up being with one of the toner cartridges. I replaced them all - and the line went away! I will need to go back now and find out which one it was, and then I'll toss that one, and I will keep / reuse the others.
Apr 01, 2009 | HP Color LaserJet 2600n Printer
ETB ASSEMBLY
Probably www.laserpros.com/pdf/HP 2600-2605 fuser-etb.pdf will help...
Oct 22, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
566 people viewed this question
Seeker5211
Seeker5211
