Question about Kitchen Ranges
Ge wb27k5140 board cant be fixed can i use a differant one
My refrigerator GE started making a clicking noise Google says defective board.would there be a different part number to replace the defective circuit board installed on my refrigerator .
like all sites you have to be advised that what you read or hear is only advice and to waste money without getting a proper diagnosis is not smart
call a GE technician in , have the diagnosis done and get a quote then decide if it needs a new board or not as it could be something different
May 30, 2016 | GE Refrigerators
How to fix key pad on ge convection oven jvm1790bk. Pad stopped working
The control panel is actually 2 different parts and either could be bad. Do you have the display still lighting up or is it completely dead? If it is out it could the main smart board. If it still lights but no buttons work then it could still be the smart board or just the key pads which are a separate part. Neither part can be fixed just replaced.
Feb 26, 2015 | GE JVM1790 Convection / Microwave Oven
GE GSS25WTGA BB
This could be a dozen different things causing this. Do you see ice build up on the back wall? Your freezer coil could be icing over and blocking fan air flow. This can be due to a bad fan, low freon.....
Oct 12, 2013 | GE Refrigerators
I have a GE refrigerator model # GSL25JFPABS. I have been told that the main control board WR55X10656 has been "replaced" by # WR55X10942 now. However I found a 656 board pretty cheap locally and...
WR55X10942 is the board that goes into that machine,it's the most up to date board out there,why would you put a first generation board in there that you know is gonna fail when they upgraded it to the WR55X10942 and that's the board it calls for now so don't put the other board in there
Apr 19, 2011 | GE Refrigerators
Washer fills but does not aggitate. happened before and we looked up online and just had to re-set it. dont remember the web site or steps to reset it though.
Sorry for the trouble if this doesn't fix it you will have to replace the control board first make sure the unit is unplugged then next you will have to remove the dash there are 4 screws at the top of it they will be a Phillips head bit or a star or hex head remove those then slide the dash down. Next remove all the wires that are plugged into the board be careful so you don't break a pin and once that is done let it sit for 10 minutes then plug all wires back into the board and don't worry about getting wires plugged into the wrong ports it cant happen there all different and once that is done slide the dash back into place and plug it in and see if this fixes it if it doesn't you will need to replace the main bored hope this helps and thank you for using FixYa!
Jan 27, 2011 | GE WJRR4170E Top Load Washer
I have a 2004 GE Profile Washer with an electronic control panel. The controls are not working and I need to reset the control panel. How do i do this?
Jan 27, 2011 | GE Profile WPRE8150K Top Load Washer
Hooked new clock control panel wb27k5140 to ge profile oven jsp38g0s3bg, clock comes on but controls dont work
The description you have provided looks like it going to be a thermal limit switch that is bad (some of them are resettable). You need to remove the control board display. Once behind there you will see 2 limit switches. Try to test both of them with an ohms meter. Both should read infinite but I am sure one is bad. Here is a link to a schematic that may help you find the limits. The part numbers you are looking for is 158 and 159. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216517&diagram_id=21205724#d21205724.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Feb 13, 2010 | Kitchen Ranges
GE D52GW12 52 in. Rear Projection HDTV-Ready Television
The ITC222 chassis actually has two different boards that are related to the power supply.
(1) Main power filter board #MIS222E0000.00
(2) Power supply #PP222E0000.37
The first board is a small board where the power cord enters. The second board is the large board that the small board plugs into.
Apr 08, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
My Fridge is less than 2 yrs old. Yesterday I heard a clunking sound coming from the fridge
to clunk,
i have a GE model PDS22SFSALSS & it did the same thing...blinking LED & clicking, then LED went blank. i read that GE was having major problems w/ the mother board, (cost for part $ 153.75 & $79.95 for service call, they couldn't tell me the labor cost!! )on many models & were re-calling some. i called GE repair 4/8/08, got no help, then i called customer service & gave them my model & serial #. they said my box would be fixed (mutha bd swapped) for free. i bought it 10/05, they came the next day & installed new board free! start w/ GE 1-800-432-2737 .....good luck
denden8148@aol.com
Nov 30, 2007 | GE PDS22SIS Bottom Freezer Refrigerator
Kitchen Ranges Logo
23 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
