Question about Digital Audio Audio Players & Recorders
I have a digital audio surround speaker system L441708 how do i hook it up to an reciever
  • Russ R
    Russ R Nov 17, 2013
    It's the only sticker on the speakers. The bass has 5 knob turn (with the hole in the middle) wire connections left, right, center, out and left, right in
    Problem Solver:
  • 10 Answers
I don't think this is the model no. please give the brand and model no.
Posted on Oct 22, 2013
3 Suggested Answers
mlapres
  • 757 Answers
SOURCE: Hooking up my Digital audio subwoofers
How did you connect it to your receiver?
Posted on Jun 19, 2009
blkitalian
SOURCE: REGENT MODEL HT391 SURROUND SYSTEM
in order to watch tv and hear sound through this system u have to have r cabe going though either ur cable box or a vca anything that is cable ready u then hook the system in to that u will then have the sound going throu the system not the tv but if r tv has a buitl in dvd player u may be out of luck sorry lol i just figred this out after having it for more than a year
Posted on Dec 18, 2009
I have a htr 6130 yamaha reciever and when i hook my five channel home theater system it plays for a while then when i turn it up to almost max it turns the unit off completly... how do i hook up my
Hook all the positive and negative wires correctly and read on the speakers and make sure you have them all in the right spot and if that doesnt help its probably because the reciever is maxed out wich is triggering a kill switch wich some recievers have as a safety feature so you dont blow your speakers
Dec 18, 2012 | Yamaha Audio Players & Recorders
How to set up my rca blue ray to my 50
You should find a Phono output on the back of the TV. Some even have a Digital Optical output as well. Depending what inputs your surround system has you should be able to hook it up to one or the other.
Aug 02, 2012 | RCA Audio Players & Recorders
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Jan 08, 2010 | Sony DAV-S300 System
No audio from cable through surround sound
you have to go to the setup for the TV audio and change it to audio out, not speakers.
May 07, 2009 | Philips Televison & Video
Would like to listen to tv through the 5.1 speakers and don't know how to hook them up to do so, please help
You can run red and white from tv out to in on reciever, or optical out tfrom tv to in on reciever or digital coax audio from tv out to in on reciever, depending on which connections you have. then you would put your reciever on aux to hear tv through surround system. Also if you have a cable box or satellite box you can run the audio from that box to the input on surround system.
Hope this helps.
May 05, 2009 | JVC TH-G30 Theater System
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hooking up surround sound
to get the digital you have to have the digital optical line or the coax rca jack digital audio connection from device to stereo reciever to get the dolby digital surround sound to work , otherwise you can only get a virtual surround sound from the reciever( no dolby digital )
Jan 04, 2009 | Sharp CDBA3100 Remanufactured Mini-System...
Just hooked up Coax cable; now talking is barely audible
is the center speaker turned up in the reciever speaker settings? each speaker can be adjusted to a level that is higher or lower or all the same as the rest. also is the dolby digital turned on in the reciever settings? and changing the surround sound pre set sounds can also improve the type of audio you are listening to in 6.1 surround sound
Dec 31, 2008 | Sony STR-DE597 Receiver
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Apr 21, 2008 | Yamaha RXV-350 Receiver
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
Top Digital Audio Audio Players & Recorders Experts
Terry Hair
Tom Chichester
Are you a Digital Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
