Question about Korg Kaossilator Pro Tabletop Synthesizer
Loose knob my program/bpm knob is loose and i cannot changes sounds or use the knob at all.
Channel 2 has gone quiet and is not working properly
Do you have the mode switch on split of stereo? The mix knob at 12:00?
Mar 13, 2013 | Behringer Vmx200 DJ Mixer 2 Channels with...
How come mmt tweak knob and select knob arent working on my line 6 pod xt live
It sounds like the pots need replacing if re-soldering didn't work. i would take it to a Line 6 authorized service center.
Line 6
Sep 01, 2017 | Line 6 New Line 6 Pod Xt Podxt Live...
Where can i get a replacement assign knob for a djx700
Behringer fired their USA distributed a few weeks ago. You'll have to call Behringer directly and request the part. Or email.goto th website
Nov 04, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
It hs no instument lighting,Chanell level indicators and master level indicator
is there power to it? does sound come out of it? if not it could be fried or about to fry. Behringer makes low end products, which tend to break fast. if you dont have any sound or lights chances are its unfixable
May 25, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How do i set the control for the crossfader on the djx700
u should b able to use it so long as you change the mode from stereo to split, then you can just use the panel at the bottom that says "crossfader:" :P
Feb 11, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How do i used the BPM counter correctlly
Hi there. BPM (beats per minute) sets the tempo of the click track. 120 for dance music.
Thanks
Paul
Jun 08, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Faulty effects behringer djx700
The effects on the PMP powered mixers flash UNTIL you push in on the selector knob. This way you can dial in the next effect number and then push in later to activate when you want it... Could yours possibly be the same technique?
May 16, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Korg Kaossilator Pro Tabletop Synthesizer Logo
46 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
