GPS Logo
N
Norman H James Posted on Oct 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tomtom will not turn on - GPS
Russ Hill
Level 3:
  • Master 4,057 Answers
  • Posted on Oct 20, 2013
 Russ Hill
Master
Level 3:
Answers
4057
Questions
10
Helped
1177479
Points
12696
Will it turn on when the power is put into it or linked to a pc vi usb lead ??
When i turn my tomtom on i only see tomtom anf symbol
If it doesn't continue to show the license and owner screen, it means that the TomTom (navigation) software is not running properly. Often it means that the software is corrupt, and it has to be repaired or replaced.
If you are able to connect the TomTom device to a computer (using the USB port), select the TomTom disk, right click and select Properties, and run the TOOLs to check and repair the (TomTom) disk. After completing the repair, disconnect it (from the computer), restart the TomTom - turn it off and turn it back on, and see if you get it going normally. If not, you'll need to restore your navigation software from your backup and see if it works. Or you can download the navigation software from the TomTom website and copy it onto your GPS device.
3helpful
Where is the reset button on the Tomtom xl340s
The TomTom XL 340-S uses the power button as a reset. With the unit turned off, hold down the power button for approximately 15 seconds, until the TomTom turns on. As soon as the unit turns on, release the power button. The unit is now reset.
6helpful
2answers
My gps tom tom turns itself on waht could be
If you search for "TomTom turns itself on", you will find that there appears to be a problem which TomTom will not acknowledge. Mine always turns itself back on exactly (to the minute) one week after being switched off and runs the battery down. Tomtom have got me to reformat and had it back for repair but the problem remains
My tomtom doesn't turn on
the green light shows when i am charging my tomtom but it doesn't turn on.
4helpful
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Tomtom Advert on Tomtom XL wont turn off
It's a default demo. You can remove it by changing it in your preferences, not by deleting files
2answers
Tomtom go 300
before you start take out sd card. 1 turn tomtom upside down. 2 see reset button? 3 use paper clip to press (press for 15secs) 4 now turn on tomtom (hold power button for approx 5secs. 5 re insert sd card. after a few minutes you should have signal. hope this solves your problem.
1helpful
2answers
My tomtom does not turn on
Contact TomTom. They were helpful to me.
Suggest u monitor battery and get it charged up. Then reset. See if you can reproduce the problem.
They sent me an email with instructions on how to format the disk or card, then reinstall the software. Then they authorized me a new map download (don't format the disk until they assure you that you can have a new map). Perhaps it's also best to  use TomTom Home software on your computer to backup the files on the TomTom incase something goes wrong.
1helpful
Tomtom 700 turns then turns its self off again
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
