Question about AquaPRO AQUA PRO 27910 - Aqua Pro Siphon Kit 27910
Aqua Pro RV Water System siphon kit, #27910 - i followed the instructions and installed the kit, valve right way, arrow pointing the right way. It does not suck the antifreeze out, it blows air or liquid back in.
  • 3 Answers
Lawrence Allen wrote: "It does not suck the antifreeze out, it blows air or liquid back in."
You have the valve installed on the outlet side of the pump instead of the inlet side. The pump does not "suck" antifreeze from the bottle but rather pumps it from the bottle. Install the valve on the inelt side of the pump and you\'ll be good to go.
Posted on Feb 14, 2014
    Sergeant:
  • 216 Answers
The valve should be closed while siphoning from the antifreeze. This allows the RV pump to draw it from the jug instead of the holding tank.
You can not use city water or other pressure to move it.
If all else fails and you are using RV antifreeze imply place the antifreeze in the holding tank. turn the valve open and use the faucets normally until you get liquid out of them.
Come summer you can simply add 1/4 cup of non-phosphours bleach to every 5 gallons of water to clean and purify tour lines and tank again.
Posted on Oct 20, 2013
How do I winterize my 2015 Jayco Jay Flight 32 RLs
Go to an RV parts store for a winterizing bypass kit for the water heater. Use POTABLE RV antifreeze and follow the instructions on the bottle. Drain all the water out of the water tank. Install the bypass kit on the water heater if it doesn't already have one. Put the water heater in the bypass mode. Add the antifreeze to the water tank. Open every water faucet including the shower head one at a time until antifreeze is present. Do this for hot and cold on every faucet. Once that is done, turn off the water pump and open all the faucets. That's all there is to it. Rember... DO NOT use automotive antifreeze. It will kill you.
Oct 24, 2016 | RVs
Tip
How to fix a refill valve
  • Brass-style toilet refill valves can often be repaired. To take a valve apart, remove the lever's screws. This allows you to lift out the float arm and valve plunger. Check the flat rubber washer on the end of the plunger. If it's worn, you can pull it out with pliers and either turn it around or replace it. This procedure usually corrects an overfilling problem. Next, reassemble the valve. If the tank continues to overfill, check to make sure the operating lever at the end of the float arm is functioning properly.
  • New refill valve. To replace the entire refill valve assembly, first turn off the water supply. The tank should then be flushed and sponged out, as detailed previously. Remove the inlet nut and riser tube from the bottom of the refill valve beneath the tank. Hold the refill valve inside the tank with a padded locking plier/wrench to keep it from turning, and remove the nut beneath the tank. With the nut off, the refill valve assembly can be lifted out and a new one inserted in its place. Follow the exact instructions included with the unit you purchase.
  • Finally, reconnect the riser tube and turn the water on. The tank should fill, allowing you to adjust the water level according to the instructions that were included with the valve.
  • Anti-siphon valves. The best refill valves offer anti-siphon protection. In fact, this may be a requirement. This protection prevents back siphonage of toilet tank water into your home's potable water supply system if a vacuum occurs in the toilet's water supply system. Whether or not this is a code requirement, the anti-siphon valve is a good idea to protect your family and public health.
on Jan 16, 2010 | Plumbing
Bowl turns on our thetford Aqua Magic Style ll rv toilet
the reason you are getting sewer gases are the wax seal under the toilet is not making proper contact with the bowl and flange....pull the toilet and replace the wax seal...buy a cant leak seal from lowes...may want to buy new bolts to reinstall...they sell plastic ones that you can cut easy after you tighten...make sure to shim the toilet if it moves...use toilet shims...also at lowes...this is why this happened to start with...it was not done right to start ...after all that caulk or grout bowl to floor...now you have a pro install...
Jun 18, 2014 | Thetford 42058 Aqua Magic Style II High...
Aqua stop hose allows water through when disconnected from Whirlpool dishwasher but stops water when dishwasher demands water
looks to me like as if the direction of the hose is incorrect. Check to see if there is a direction of flow arrow on the hose and point that arrow away from the tap towards the machine.
Jan 15, 2014 | Whirlpool ADG175 Builtin Dishwasher
Installation manual for Camco 36543 RV PUMP Converter Winterizing Kit
Couldn't find instructions per se, looks pretty straight forward. Take intake line off of pump, install coupling and valve on pump and reattach tank line to valve so that water will be sucked from tank through valve to pump and out to system. Attach hose that comes with kit to valve and it is used to pull antifreeze from jug when you move valve handle to other position.
http://www.campingworld.com/shopping/item/pump-converter-winterizer-kit/6279#relateditems
Sep 27, 2012 | Camco 36543 RV Pump Converter Winterizing...
How to fix the pedal flush on a Tetford Aqua Magic IV
I saw the other answers and what are they talking about. thetford is a rv toilet the two bottem pedals are control by cable one cable broke You just have to get pedal repair kit pull toilet out and repair I have a repair kit coming as we speak exact same problem
Apr 16, 2012 | Thetford Home
Have a maytag washer model lat9306aae and it will fill right the first time but when on the rinse cycle it wont fill up keeps running out ?
Check the drain hose behind your washer. If if is too low you will get a siphon and the water will run in and not fill up the tub. The drain hose is supposed to have an anti-siphon valve / kit on it if installed correctly but not always. Lift the drain hose until the end elbow is nearly even with the bottom of the top panel lip.
Any local appliance part center will have this Siphon Break Kit:
http://outlet.whirlpool.com/-[285834]-300125/285834/
There is a rubber diaphragm valve in the top of the "T" that opens to introduce air into the drain hose to prevent a Siphon. Installation is simple. Lift your drain hose up vertially, Make a cut 4 inches from the bottom of the top panel. Install the T with the rubber end UP and connect the elbow you cut off to the T oulet and drain.
Thanks for choosing FixYa,
Kelly
Apr 02, 2011 | Washing Machines
8" shower head with thermostatic
your litre per minute usage is probley greater than the recovery time on the cylinder..install a dual coil cylinder and pipe a heat exchanger off central heating system through second coil and you shall double the recovery time on tank,both coils should be controlled through pipe stats for effiency purposes
Jan 15, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
AquaPRO AQUA PRO 27910 - Aqua Pro Siphon Kit 27910 Logo
129 people viewed this question
Top AquaPRO Plumbing Experts
Donni Steen
Tom Chichester
Are you an AquaPRO Plumbing Expert? Answer questions, earn points and help others
