Question about Sewing Machines
When pressing foot pedal machine responds very slowly when the pedal is pressed all the way down
  • Sewing Machines Expert
  • 458 Answers
Have you checked the pedal for fluff or anything that might be stuck in the pedal. Are you using it on a thick carpet? Try putting it on a board and using your hand to test it
Posted on Oct 19, 2013
MakikiChris
  • 84 Answers
SOURCE: Doesn't sew
Hi emnsam....please update your post with the complete Model Number in it's entirety and I will be able to advise you.
Posted on Aug 02, 2007
  • 13 Answers
SOURCE: Bernina Activa 135 foot pedal problem
If you can get acess to or borrow another foot pedal to try I would do this first any of the Activa, Artista range fit to try. The fault may not be in the foot pedal but in the main CB of the machine. This can give a fualt of lights on but no motor drive. In this case the board would need replacing by a technician. Hope this may help.
Posted on Jun 23, 2008
SOURCE: foot pedal and thread guide
Same thing happened to my CE-200. It would only stitch one stitch at a time or else it would run full speed. My husband made an adjustment through a small hole on the back of the pedal and it now works much better. The adjustment hole apparently allows you to set the sensitivity of the electronics inside the pedal. He turned it slightly toward the + direction. It took a couple of small adjustments to get it to work nearly normal again.
rbwinter@wbsnet.org
Posted on Jul 14, 2008
  • 166 Answers
SOURCE: my machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
Posted on Jan 02, 2009
  • 96 Answers
SOURCE: Husqvarna 2000 sewing machine foot pedal stuck on but not pressed
you may need to take foot pedal apart and clean it the contacts inside may be dirty and causing it to stick
Posted on Dec 13, 2009
My foot pedal has no power
Not sure what you mean here. Do you mean that the effect is similar to not being able to press the pedal down far enough so it is only running slowly? The control system will be very simple as it only has to control the current. My first step would be to open up the pedal and see if the control is properly connected to the pedal -otherwise am making a blind guess.
Feb 02, 2015 | Sewing Machines
Machine is sewing very very slowly no matter how hard I press the foot pedal
This happens to me when my pedal isn't connected all the way onto the machine. Disconnect it and then push it back on firmly. I have also had it happen when the Pedal was about to break. I had to go and buy a new Pedal at the repair shop and it fixed the problem.
How do I fix the speed of stitching? When I press on the foot feed I get almost no speed from it.
unless it has been progressively getting slower, I did have a simular issue. My pedal was getting "stuck" at the 1/2 mark. (wasn't pressing all the way down). Drove me nuts. Took the machine apart, cleaned oiled, cleaned again blah blah blah...when the pedal was the last option took it apart and found a nut from a screw had gotten inside the pedal and stopping it from pressed down. There could be a burr, a nick or something it is catching on.
Sep 22, 2014 | Janome Memory Craft 4000 Sewing Machine
Bernette 46 Motor
sounds more like a foot pedal fault rather than the motor, try another foot pedal. It sounds as if yours is faulty
Feb 10, 2014 | Sewing Machines
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Feb 07, 2014 | Bernina Sewing Machines
Toyota sewing machine foot pedal unresponsive then goes really fast.
Try to get another foot pedal. If that works then replace.
Oct 08, 2012 | Toyota Sewing Machines
Bernina Nova 900 air-pressure foot pedal going really fast all of a sudden
the foot pedal would have to be check at a sewing machine shop & they
could tell you more about weather it would be easy to fix or not
Apr 21, 2012 | Sewing Machines
Singer 9113 - The machine slowly stops
have you checked the connection of the power cord to the machine?
have you checked the connection of the pedal cord to the machine?
if these are securely connected, then you may need a new foot pedal
Mar 28, 2012 | Sewing Machines
Why isn't my husqvarna foot press not connecting giving power for my needle to move. Machine does have power but does not run when pressing foot press.
have you checked to make sure the foot pedal is connected correctly to the machine?
if the foot pedal is connected correctly, then the machine needs to be checked to see why it's not responding
Mar 27, 2012 | Sewing Machines
Foot pedal dead, machine keeps sewing!
There is no suppressor in the foot control of a 425. Only the control unit, which may need to be replaced. If the machine accelerates to full speed, it may have a problem with the "stop right" board which tells the machine whether to stop with the needle up.
You could have several problems, so go see a qualified Husqvarna repairman. You may contact Husqvarna customer service to locate the best one in your area.
Mar 12, 2008 | Husqvarna Freesia 425
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
