Question about ASUS Eee PC 1005PE (SeaShell) Netbook
Calibrate screen It seems like my screen has been push down to a point where I can't see my tool bar or the bottom of a page.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 57 Answers
Which toolbar you are looking for?
If I understand correctly then you can try to set screen Resolution by going to Start -> Control panel -> Just look at the bottom of appearance option and there you will see the option of screen resolution. Try it and let me know if you need more assistance.
Posted on Oct 20, 2013
Fix screen problems
I am not familiar with your application but I game on line. Sometimes I have problems on the corners of my screen and using tool bars there. What I do is change the resolution of the computer either in game or not in game and when I make it larger or more pixels more detail, that seems to fix the problem.
Apr 26, 2014 | Computers & Internet
When i turn my 3ds on you can see all the top screen but not the bottom screen
Plug it into the charger first.try calibrating the touch screen.
you can get to the calibration menu without touching the touch screen. First, turn off your system. Hold down L+R+X. While holding these buttons down, press the power button. This should take you to the touch screen calibration menu. (See Nintendo 3DS Operation Manual, Page 15)
If it doesn't work,you need to replace the bottom screen.
please note that all games dont require the bottom screen
Jul 01, 2012 | Video Game Consoles & Games
My stating button is at the top of my screen how do i adjust
PUT YOUR CURSUR ON THE TOOL BAR THAT YOUR START BUTTON IS ON.
PRESS AND HOLD THE LEFT BUTTON ON YOUR MOUSE.
WHILE HOLDING THE BUTTON DOWN DRAG IT DOWN THE SCREEN TO THE BOTTOM.AS YOU DO THIS YOU SHOULD SEE THE WHOLE BAR MOVING DOWN, PERHAPS FIRST MOVING TO THE RIGHT OR LEFT VERTICALLY AND THEN ON DOWN TO THE BOTTOM OF YOUR SCREEN.
WHILE AT THE BOTTOM RELEASE THE LAFT BUTTON ON THE MOUSE, THE BAR AND START BUTTON SHOULD NOW REMAIN IN THE LOWER SECTION OF YOUR SCREEN..
Jun 23, 2012 | Computers & Internet
Hello i have a wii remote that cannot point in home menu in all games and in some specific games like mario galaxy and metroid generally but the only way to point in home menu and these games is to go very...
You may have to adjust your sensor bar settings.
From your wii home page (the page that loads when you start the system) use your wii mote to select the Wii button (bottom left) then select "Wii Settings"
Push the next arrow push "sensor bar"
Here you can either adjust the position of your sensor bar (top of your tv or bottom) and also calibrate the sensitivity of your wii mote.
hope it helps!
~good luck!
Mar 07, 2011 | Video Game Consoles & Games
I have trouble calibrating my top shot elite for PS3. I am on a 92" projection screen. The sensor bar is at the bottom of that screen. While raising the gun enough to point at the target, the...
you need to be back further maybe for that large of a screen size try re sincing your topshot and the usb plug in and set your dead space to as large as it will go work for me on my 55 in hatachi
Dec 28, 2010 | Activision Cabela's Dangerous Hunts 2011
I want to shorten my watch band on my new Casio MTG900DA-8WC It has a metal band
In order to remove the links of your Mtg930 watch you will need a couple of tools . It is recommended to have a watch pin pusher and a spring bar remover tool in order to do so. If you do not you can use a small precision flat head screw driver , the size that is usually used to fix glasses or smaller.
First you need to lay a cloth down at a table . Lay the watch on top of cloth to prevent scratching . flip the watch upside down and have a good at the back of the watch bracelet.
If you look carefully you are going to see notches on the back of each link with an arrow pointing in. This is where the spring bars are accessible and can be pushed in to remove the link.
You need to place your spring bar remover, pin pusher or precision screw drive in the notch against the edge.
Mean while push the opposite side of the watch link up so you can see the most of the spring bar inside the notch.
The spring bar is going to look like a pink with a notch on the the top then gets smaller. As shown below on the left side of the picture. If you are looking at the notch on the spring bar, that is where you need to get our tool ontop of . So you can push down the spring bar.
Once you push down on that notch on the spring bar the link will be able to slip out . Without a spring bar remover it will be more difficult and you will need to be patient as you try to work your flat head screw driver into the notch and be able to push down . Once the pin is push down you need to pull the link from the rest of the bracelet.
Do not be surprised to take anywhere from 5 to 30 minutes if you have no experience and not have a spring bar remover.
Once you removed all the links you desire , You will need to put the spring bars back into the links and close the watch bracelet up.
The easiest way is to slip spring bar into middle of link. Bring the other end of the bracelet over so it the bottom covers the other link with the spring bar head out. Push the spring bar down with your tool as you slide the links back together.
Oct 17, 2010 | Casio G-Shock Atomic MTG930DA 8VCR watch
Sony Bravia KDL-52XBR6 screen adjustment
That sounds very normal to me. When your watching a HD channel, and a commercial comes on and the screen gets smaller with as you say the black bars, just means that the commercial is not broadcasting in HD. You can change it by pushing the button on your TV remote that says picture, but you are streaching the screen and are going to loose the quality of the picture. You may also want to spend a few hours, going into you TV settings and just start playing with the settings. Just remember where they were before you change something. You can also purchase a guide to LCD settings to point you in the right direction. If you have your TV set to vivid or one of the preset picure modes, it is costing you more power and you are not getting the best picture that the TV can produce. Play around with the custom setting or buy one of those calibration CD's off the internet.
Nov 09, 2009 | Sony BRAVIA KDL-52XBR6 LCD TV
How to fix timing on a juki ddl-555 sewing machine
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Sep 14, 2009 | Juki DDL-8300
When printing a greeting card the copy appears too low on page so one fourth of an inch is cut off on the bottom of the page.
On Printer press Menu button.
Scroll down to tools an press ok.
Scroll down to Align Printer and press ok.
The Printer will calibrate automatically.
May 11, 2009 | HP Photosmart 8250 InkJet Printer
Can't get Audio tracks to play on any myspace page
I'm wondering if you can't play .mp3, .wav or other audio files on your computer, or just Internet Explorer, or just specifically myspace.
First try: Open Internet Explorer. Select Tools from the Menu list. (If you do not have a menu list, right click the gray area below the url bar and select menu bar from the drop down list)
Select Internet Options from the Tools Menu. Select the Advanced Tab. Scroll down to the Multi-Media heading. Make sure that "Play sounds in web pages" is checked. Close Internet Explorer, re open and test.
Apr 15, 2009 | MySpace Social Network
ASUS Eee PC 1005PE (SeaShell) Netbook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
