Question about Technics SUV500 2-Channel Amplifier
Dont know what wires i need to hook up my suv-98 amp and tuner to work and does it have to have shorting pins to work
When I connected diagnostic/testers to the OBD-II connector on my 2007 Hummer H2 SUV, they did not work at all, does anyone know why ? What are the exact pinout of this connector on Hummer H2 ?
Data Link Connector (DLC) Pin
Wire Color
Circuit No.
Function
Not Used
PU
1132
Class 2 Serial Data
Not Used
BK
1050
Ground
5
BK/WH
1851
Ground
6-15
Not Used
16
OG
640
Battery Positive Voltage
Dec 26, 2014 | 2007 Hummer H2 SUV
How do i hook up my car speakers to an aftermarket cd play in a 98 ford explorer
Is the CD player independent of the tuner or is this an all in one unit.
Jan 29, 2013 | Car Audio & Video
I have a kenwood stereo for 2000 saab 9-5. the tuner works but whenever i change it to cd you can no longer hear any music. it must be the wiring but i dont know which color wire is connected for the cd...
It sounds you are using an amplifier and using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). Try hooking up the blue/white wire to turn your amp on. When leaving tuner mode, the blue wire shuts off, turning off the amplifier.
Sep 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
My HDMI inputs #2,3, & 4 no longer work. I have my Direct TV hooked up to the #1 & my Playstation 3 hooked up to the #2. The # 1 still works, but the others don't. Idid try all of them out also....
Unplug the tv about an hour to let it reset itself.Replug,reset everythings in ur tv menu back to factory setting.All ur functions on the Tuner board should work again.Not than,ur Tuner board is defective,have all those shorted HDMI input Hubs.The only way now it to replaced the Tuner board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Ford Esc 98 left signal (front & rear) not working. Hazards work
it sounds like your flasher is going out and if not that then it could be a short in the system
Aug 22, 2009 | 1998 Ford Escort
Help asap
hook blue wire to ur radio to amp remote
Feb 12, 2009 | Sony Car Audio & Video
XOvision DVD/ Tv Tuner
the brake wire is connected to your hand brake to stop you watching tv while you r driving its a safty thing as you have not connected it it might be why you cannt watch tv hope this is of some help
Dec 27, 2007 | XO Vision GX1211 XOVision 12" Roof Mount...
Technics SUV500 2-Channel Amplifier Logo
26 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
