Question about Royal 110 DX Cash Register
I can't register an amount without getting an error!!
How will solve the error e029 in Casio CE 6100 ? I got the user manual but it's too complicated and not clear so pls help me ((
Sounds like you under tendered a sale and the register is waiting for the final amount to be paid on the last sale.
Try this -
Press subtotal. If an amount shows on screen, type that amount (without decimal point, so if you see 23.80, type 2380) then press cash button
Jan 21, 2017 | Retail Supplies
WHY DO I GET AN AUDIBLE SIGNAL AND ERROR CODE WHEN I TRY TO ENTER A SALES AMOUNT ON MY CASH REGISTER
It sounds like an entry limit has been set. This is often called HALO (high amount lock out) in many manuals. Look in your programming manual to see if there is a limit function. If you need a programming manual, one of the users has most of them here:
https://the-checkout-tech.com/
Oct 08, 2015 | Retail Supplies
How to get the amount of change back on a sharp xe-a404? Like, how to do it without using mental math.
key in amount n department key press d
subtotal key in amount given n press key to opn drawer should show change to be given.go on sharp webdite n download manual
Jul 20, 2014 | Retail Supplies
I have an error on the cash amount tendered button. It automatically takes 71 cents of the amount when i press the button.
You have programmed the Cash key in P1 mode to 71 cents. To reverse this turn key to program enter a clerk if needed and put 00000000 hit Cash key then Subtotal turn key back reg.
May 28, 2014 | Casio TE-2200 Cash Register
Rang in 3.50 customer gave $10-when you enter amt tend you get error
turn the key to program and enter (0) , cash, then subtotal . then hit 3 subtotal, (0) cash, subtotal. turn the key back to reg and the cash key should now function correctly
Jan 07, 2014 | Casio PCR-T2000 Cash Register
I was given a casio TE900 cash register and there is an eo37 error on it. How do I fix it. I was not given a manual and I really dont want to purchase one. Can someone please help
Error E037 is a high amount lock out/low digit lock out error. So you're probably entering an amount that is over the high amount limit. The manual can be found here: http://parklandbm.com/downloads/CASIO%20TE-900%20Operators%20Manual.pdf
For the steps to change the high amount limit, see page 31 of the manual. See also page 32 for an example of the high amount limitation.
Oct 24, 2013 | Casio Parts Cash Register PC Desktop
E-037 accidentally I set higher quantity block too low and i can`t register anything over 20
For error code E037- turn key to program- push 0 then cash amount tend button then subtotal button. Let it work. When receipt is finished printing... Will be long...push 0/cash amount tend button then sub total. Turn key back to register mode and you will be back in business.
Oct 18, 2012 | Casio PCR-T220S Cash Register
Sir good evening i have cash regester casio 160cr.Error code is e94 pls help how i can run my cash regester thanks.
I suggest you to reset your equipment.Here is how:
Remove AA batteries and unplug register from wall for 15 minutes.
Two more options;
Option #1:
To print the transaction details before clearing the journal memory:
VERY IMPORTANT: Do not interrupt once printing begins or the journal will not be cleared.
1. Make sure the paper is full in the register.
2. Turn to Z mode.
3. Hit the RC key until the screen displays "E94".
4. Hit Cash Amount Tender.
Once the printing is completed, the journal is cleared and the register is ready for use.
Option #2:
To clear the journal memory WITHOUT printing the transaction details:
1. Turn to Z mode
2. Hit RC key until the screen displays "E94 Clear"
3. Hit Cash Amount Tender
Nov 27, 2010 | Casio Parts Cash Register PC Desktop
Casio 240 Cash Register: Error 01
The reason it went into error is due to someone turning the key to another mode without finishing the current transaction. Turn the key to each mode until you find the mode that doesn't give error 1. If that mode is X or Z, then press SUBTOTAL. If that mode is REG, then press SUBTOTAL to see the amount due, then type that amount and press CASH
Need a manual for a Casio 240CR? Try here:
http://the-checkout-tech.com/manuals/cashregisters/Casio1.php
Many others at http://the-checkout-tech.com
Mar 26, 2010 | Casio Parts Cash Register PC Desktop
Royal 110 DX Cash Register Logo
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
