Question about Pyle Pl1157rd Led Brake Lights Light Bulbs Pl1157rd
High mount brake light works, but tail brake lights dont 2000 mercury mountaineer
    New Friend:
    Problem Solver:
  • 18 Answers
I'd check the bulbs and wires on tail lights. Sometimes bulbs go out of place and wires corrode. In my car (not a mercury though) I had to give a little smack on the light to get it working. Of course, eventually I cleaned all wire connections (including ground wire) inside the light and all works now. I had a problem with one light though so if both tail lights are out it might be wires broken/shorted on the way from splitting point where one section heads to the high mount brake light and other to the tail light.
Would be good to check the fuses too, they might have different ones. If blinkers and reverse also don't work then it's more likely wire problem like I stated before.
Posted on Jan 17, 2014
Tail lights not working
All of the marker and tail lights are powered from a 15amp fuse going thru the headlight switch on a brown wire. Do you have power from that circuit coming out of the headlight switch ?
Jan 25, 2014 | Mercury Cars & Trucks
2000 Mercury Mountaineer tail lights work, but brake lights not working? High mount brake light is working.
Do you have a trailer harness hookup on the back? Sometimes the wire get corrosion in the plugins and cause what you are talking about. I would try unhooking them first.
Oct 19, 2013 | Mercury Cars & Trucks
Where do i buy a high-mount brakelamp at for a 1997 mercury mountaineer?
do you mean 1 of these?
http://cgi.ebay.com/ebaymotors/3RD-BRAKE-LIGHT-HIGH-STOP-LAMP-95-96-97-FORD-EXPLORER-_W0QQcmdZViewItemQQfitsZYearQ3a1997Q7cModelQ3aMountaineerQQhashZitem2eb36deea7QQitemZ200578821799QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Mar 07, 2011 | 1997 Mercury Mountaineer
I have a 2000 Mountaineer. The front parking lamps are missing along with the bulbs. Does anyone know what exact bulb is needed to replace these? Many thanks
2000 Mercury Mountaineer Auto Light Bulb Size Guide
Low Beam Headlamp Light Bulb Size: 9007
High Beam Headlamp Light Bulb Size: 9007
Parking Light Bulb Size: 3157NALL or 3457ALL
Front Turn Signal Light Bulb Size: 3157NALL or 3457ALL
Rear Turn Signal Light Bulb Size: 3156LL
Tail Light Bulb Size: 3157LL
Stop Light Bulb Size: 3157LL
High Mount Stop Light Bulb Size: 922
Fog/Driving Light Bulb Size: 9006
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 3156LL
Front Side Marker Light Bulb Size: 916NA
Ash Tray Light Bulb Size: 161 or 194
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 168
Step/Courtesy Light Bulb Size: 168 or 906 or 912
Trunk/Cargo Area Light Bulb Size: 211-2 or 562
Under Hood Light Bulb Size: 906
Instrument-General Light Bulb Size: 194
Check Engine Indicator Light Bulb Size: 194
Hi-Beam Indicator Light Bulb Size: 194
Seat Belt Indicator Light Bulb Size: 194
Brake Warning Light Bulb Size: 194
Automatic Transmission Indicator Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: 194
Feb 17, 2010 | 2000 Mercury Mountaineer
Tail break lights don't work. Window break light does work however. Bulbs have been replaced.
Check the brake light fuse. The high mounted brake light (third brake light) is on a different circuit than the brake lights. Hope this helps.
May 23, 2009 | 1998 Mercury Mystique
Instrument cluster lights and tail lights went out
if its not the fuse then you have a bad headlight switch
Mar 13, 2009 | 2002 Mercury Mountaineer
Pyle Pl1157rd Led Brake Lights Light Bulbs Pl1157rd Logo
128 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
